HUGE parts sale/part out!!
located in SAN ANTONIO TX.. WILL SHIP AT BUYERS EXPENSE!
YOU CAN ALSO FIND ME ON SANANTONIO-IMPORTS.COM
SCREEN NAME= EkillinEM
EVERYTHING MUST GO!!!!!! ANY RESONABLE OFFERS WILL NOT BE REFUSED!!
KOYO full size radiator$225 obo
obd1 stock p28 $100
ACT prolight fly wheel,ACT 6puk clutch,ACT pressure plate $325obo takes all
fresh obd1 dizzy with fresh NGK wires $140
TAKATA 6 POINT long HARNESS $350 comes with everything to install on ur car..
skunk2 cam gears $175 anodized blue
skunk2 pro3 cams $400 FIRM.. or $550 for cams and cam gears :surething:
BDL FUEL RAIL "H" series new $100 firm
RC 310cc injectors $110
FAL slim fan $75
EM racing triangular bars for EK $350 OBO(set of 3)
EM racing triangular bars for DC/EG/EF $350 obo(set of 3)
$1350 obo takes complete bottom end!
LS b18a1 BLOCK WAS HOT TANKED AND BEAD BLASTED --> serial # 1310542 LEGIT from JJ's motorsports
shot peened ls rods
ARP rod bolts (0 miles)
Golden eagle block guard( 0 miles)
LS crank (also hot tanked)
CTR pistons w/ oem rings 12-5 compression (bout 500 miles) took out of my other motor
ITR Oil pump ( 0 miles)
ITR water pump ( o miles)
ACL rod bearings and all other bearings were replaced NEW!! (0 MILES)
HEAD GASKET (0 MILES)
oil pan
HEAD: $ 550 takes everything or I WILL PART OUT!!!
PORTED ITR head with stock b16 cams/ cam gears $400
(head is already tapped for lsv)
ITR intake manifold $120
ITR tb $65
BDL came seal
vtec solonoid
hondata intake manifold gasket $45
ARP head studs $110
polished valve cover
obd1 stock p28 $100
FAL slim fan $75
shot peened ls rods
oil pan
ITR tb $65
BDL came seal
vtec solonoid
ARP head studs $110
I only see 4 straps on harness, does it come with eye bolts 2 bolt down 2 chassis and/or are the short version? Lmk I might be intown 2mrw 2 get balleurs wheels=]
clutch and and everything is b-series..
only trades mite be for parts for my 97 ek hatch
ebydrc
Sep 23, 2007 04:45 PM
