Next set of mods for noticeable power gain
Old Sep 3, 2002 | 12:27 PM
90-CRXSi's Avatar
Default Next set of mods for noticeable power gain
I have a b16 w/ CAI and full 2 and 1/4 exhaust. I would like to make some mods that will really make a difference in power. I have around 2500 bucks to spend, and got the motor form HMO so I don't really know how many miles are on it. Should I mess with new cams, vtec/fuel controllers, and head work or save up for a turbo setup. Any input is appreciated.
Old Sep 3, 2002 | 12:34 PM
spettinger's Avatar
Default Re: Next set of mods for noticeable power gain (90-CRXSi)
CTR intake cam, valvesprings and retainers, skunk2 lightweight valves, throttle body and intake manifold, mugen head gasket, light weight flywheel and clutch (toda and exedy ) DC 4-1 header with 2.5 " collector. if you have some time, have the runners on the head hogged, (sharpened) and port it out a little bit. AEM standalone with the change. HA!
[Modified by wreckedhatch, 9:35 PM 9/3/2002]
Old Sep 3, 2002 | 12:36 PM
Urban Business
Guest
Posts: n/a
if your want to turbo turbo... P&P head lower your compression or boost less. will be more expensive in the long run but higher gins hp wise.
NA: ctr cams (longest duration out of any oem cam) or crane crower etc. (increases hp) you WILL need to add more fuel (8hp usually w/ oem cams, up to 30 w/ aftermarket ones)
valve train, springs, retainers over sized valves (higher redline, extended power curve)
P&P head (<=30hp)
lightened flywheel (kicks *** on the freeway hard too hookup on launch w/o good tires and suspension
vafc for vtec activation at desired rpm. also you can adjust your fuel maps (great w/ cams)
nitro: ghey boost but works 30 to 85485643865-843 hp
suspension, suspension is VERY important when launching or racing (real racing, draging isnt racing, thats shifting)
weight reduction. fully gutted hatch is usually 5mph increase out of every gear
adjustable cam gears dunno hp, has to be tuned on a dyno
lots of NA **** aplies to fi. fi key is low compression, low duration high lift on cams, strengthed internals
na key is high duration low lift on cams, high compression
jg intake manifolds (na or fi) and exhaust manifold ( na) own
port an itr t boddy, aftermarket ones tend to bend and **** up (they're alumninum)
pullys help, get rid of power steering and ac
best mod is this: planning. look at wallet, look at time slip every seccond w/ bolt ons is about $1,000 however freemods cant be beat
[Modified by TorteX, 3:43 PM 9/3/2002]
Old Sep 3, 2002 | 12:59 PM
Chris_'s Avatar
http://www.gude.com
email them about their head package about 2 grand after core gets you a whole new head. email them and they will send you dyno charts and whathave you
Old Sep 3, 2002 | 06:10 PM
StorminMatt's Avatar
Default Re: Next set of mods for noticeable power gain (crxconnection)
You might also want to buy a header. Headers don't do much for a stock B16A. But if you are going to get cams or do port work, they will be very beneficial.
Old Sep 3, 2002 | 06:17 PM
BoostedED9's Avatar
Default Re: Next set of mods for noticeable power gain (StorminMatt)
i have a spoon 2ply head gakset for sale for a b16.... it will raise your comp ratio
Old Sep 4, 2002 | 12:29 PM
drunk's Avatar
500 bucks NOS
Old Sep 4, 2002 | 12:37 PM
Mr Furball's Avatar
Default Re: Next set of mods for noticeable power gain (drunk)
itr cams, ctr pistons & valve train, jdm 4-1 header, flywheel good set of tires and light wheels in 15IN
Old Sep 4, 2002 | 12:43 PM
Doctor CorteZ's Avatar
you are 100% wrong
a 2.5" collector header is one of the best mods you can do
cold air doesnt do **** except kill throttle response
Old Sep 4, 2002 | 12:56 PM
raene's Avatar
Default Re: Next set of mods for noticeable power gain (Doctor CorteZ)
Cold air dropped me 0.2s in the 1/4 mile, so I'd have to disagree.
Old Sep 4, 2002 | 01:14 PM
Brandon Chun's Avatar
Default Re: Next set of mods for noticeable power gain (raene)
Ctr Cams/Itr Valve Train, or some aftermarket cams, port and polish, jdm 4-1, Itr ported tb, Skunk 2 Manifold, tuning, maybe a small shot of nitrous. For the money you could probably get a head package from somewhere.
Turbo would be nice, but I'd have some more money after that saved up
Old Sep 4, 2002 | 01:31 PM
89civic1.8T's Avatar
Default Re: Next set of mods for noticeable power gain (Brandon Chun)
Just do a custom turbo setup! Your stock engine will be fine if you keep the boost low (8 psi) And if you get really good engine managment (Hondata, Zydne) You can run even more! You could get a greddy SOHC kit for 1500 or less if you can get it used and have a really nice setup that should get you in the 13's easly. The extra 1000 would pay for a Zdyne GOLD SECU + 450 CC injectors.
Old Sep 4, 2002 | 01:46 PM
Loco Honkey's Avatar
Default Re: Next set of mods for noticeable power gain (89civic1.8T)
Terbough! The B16 is a torqueless overhyped wunderslug. Give it some boost so you gain torque.
Old Sep 4, 2002 | 02:08 PM
bfrank81's Avatar
Default Re: Next set of mods for noticeable power gain (F=WT)
NNNNAAAAAAAAAAAAWWWWWWWWWWWWWSSSSSSSS!
Old Sep 4, 2002 | 06:30 PM
wickedxboi's Avatar
Default Re: Next set of mods for noticeable power gain (bfrank81)
go with the turbo
Old Sep 4, 2002 | 06:41 PM
ijjz's Avatar
Default Re: Next set of mods for noticeable power gain (wickedxboi)
home made turbo!!!
Old Sep 4, 2002 | 07:37 PM
Default Re: Next set of mods for noticeable power gain (ijjz)
Can I just say turbo again?
Old Sep 4, 2002 | 07:41 PM
ijjz's Avatar
I will say it agian my self. http://www.homemadeturbo.com/
I am sure you are well aware of this page, if not then great! It is a nice site to learn how to build your own.
Old Sep 4, 2002 | 09:08 PM
W0oT's Avatar
Banned
i agree completely... i have a lot of stuff for my b16 but the idea that i could turbo my b16 for 1000 dollars was too good to be true... i'm planning on running the tdo4 w/ dropshop manifold. saab 93 fmic, 1g dsm bov, 1g dsm turbo injectors, hondata, vafc, and msd boost retard. prolly run 9-10 psi boost. on stock internals.
Old Sep 4, 2002 | 09:40 PM
JAMinCiViC's Avatar
Default Re: Next set of mods for noticeable power gain (Nismo240sx1)
TURBO...
Old Sep 4, 2002 | 10:08 PM
big pete's Avatar
Default Re: Next set of mods for noticeable power gain (Mout12)
go turbo....you could piece together a turbo kit something like the drag kit for 2000-2500
L-TownGSR
16
May 13, 2005 07:54 PM
Audio28
May 11, 2003 07:38 AM
TroyL
Nov 10, 2002 05:17 PM
Comtechgsr2000s
Feb 7, 2002 02:32 PM
Yellow Dragon
May 2, 2001 10:52 PM
