boring a b16 with stock pistons
Old Dec 24, 2009 | 11:31 AM
v8killaz's Avatar
Default boring a b16 with stock pistons
ok how much should i bore and still be able to use stock oem pistons and rings
its a b16a2 but i blew the rings in number 4 cylider and may need a bore
Old Dec 24, 2009 | 01:30 PM
thumper64's Avatar
Default Re: boring a b16 with stock pistons
If you bore it, get oversized pistons. You can hone the walls if you can't see the scratches.
If you are at all considering boost, do it now.
Old Dec 24, 2009 | 01:59 PM
metal41mulisha's Avatar
if your cylinders are oversize then the pistons have to be too. not a hard concept
Old Dec 24, 2009 | 03:11 PM
Mufasa's Avatar
King of Lions
your going to have to go with bigger pistons if your going to bore out your b16
Old Dec 24, 2009 | 03:18 PM
nix94delsol's Avatar
about .0000
Old Dec 24, 2009 | 04:48 PM
z6hatchboy's Avatar
youll need bigger pistons but whatever you do the main and most important thing is to have the piston to wall clearance right. Im thinking it might be around .001"-.002"
Old Dec 25, 2009 | 11:47 AM
v8killaz's Avatar
ok guys i cracked my engine today and relized the pistons are fine, rings are fine, no deep scratches anywhere
and the engine spins nice and free
on the other hand the exhuast valve shattered pretty nicely
so new ?
should just change the valve and be done with it
or should i take it to a machine shop and have them reseat the valve
the seat looks fine no dents or anyhting visible, only some small nicks which i could file off
ill be getting new valve seals also, and i may just throw in some rings if i feel the need
what u guys think
Old Dec 25, 2009 | 01:54 PM
slo_hatch's Avatar
i would put new rings and bearings in it since you have it all apart. but if your valve broke you will have to get a new valve...idk how your saying reseat a broken valve. and most likely your gonna have to replace more than one. others may be bent. i would take it to a machine shop and let them look at it to make sure everything is ok
Old Dec 25, 2009 | 03:08 PM
v8killaz's Avatar
i was talking about getting the seat machined
Old Dec 26, 2009 | 09:49 PM
quilksilver's Avatar
take the head to the machine shop n let them check it out, if i were you i would just rebuild the whole motor
Old Dec 26, 2009 | 11:50 PM
v8killaz's Avatar
well rings, bearings, head machined, seals, gaskets, clutch, everyhting checked over
will be good enbought for me
i mean it was a damn healthy engine
every cylinder was 200psi compression, and i mean every one was exactly 200 not even off by 2 psi
Old Dec 26, 2009 | 11:55 PM
93egSLEEPER's Avatar
Bore it to 82mm get new pistons and rings and get a tune. you will gain some power and .2ish in compression points.
redo all the bearing (mains and rods) and redo all the valves/valve seats. dont half *** it or you will just be tearing it down again.
duffman1278
Jul 29, 2008 07:41 PM
Black R
Mar 17, 2005 07:22 PM
95c1v1cs1
Jul 28, 2004 09:44 AM
Black DC2
Jun 1, 2003 06:22 PM
BlueSi2k
Feb 27, 2003 11:18 PM
