94 civic a/c clutch problems
Old Dec 24, 2009 | 10:47 AM
thaisayz's Avatar
Default 94 civic a/c clutch problems
my a/c fan runs - the compressor run - but not the clutch. What is wrong? heater works but not cold a/c.
Old Dec 24, 2009 | 05:21 PM
davey5300's Avatar
Default Re: 94 civic a/c clutch problems
you know why? Its because your posting in the accord forum when you should post in the civic forum
Old Dec 26, 2009 | 01:07 AM
slomofo's Avatar
GDD Member
You're probably low on freon, but if you go to the receiver drier, there's a 2 pin harness that connects to the a/c pressure switch. Unplug the harness and jump it. If the clutch kicks on and stays on, it's probably low on freon or has a bad pressure switch. If the clutch doesn't kick on at all, you'll probably need a new compressor.
Davey5300 - Civic, Accord, BMW, Camaro, doesn't matter what forum he posted in, this is a universal problem.
rockycat
Aug 26, 2014 05:35 PM
thaisayz
Dec 24, 2009 11:36 AM
all-mtr-teg
Mar 1, 2008 11:32 PM
