93 honda accord surges and revs high
Old Dec 24, 2009 | 04:11 AM
staudi24's Avatar
Icon3 93 honda accord surges and revs high
I have a 93 honda accord I have checked vacuum lines and all. I have replaced the iac vavle and fast idle thermo valve. Also habe replaced fuel regulator valve. But when the engine is cold it won't surge but when it warms up and I get up around 50 to 60 mph the engine kinda surges when I hit the gas pedal like it will speed up die off and speed up repeaditly. When I stay steady at like 55 or 60 it will sound like its reving high and then the pitch will change and it will run better. If it means anything in the summer when it gets extremly hot inside the car it won't start anthe tachometer bouncings and. Doesn't read right.
Please help been fighting this for a year now. Someone also said maybe a vehicle speed sensor.
Old Dec 24, 2009 | 06:34 AM
chibyuza18's Avatar
New User
Default Re: 93 honda accord surges and revs high
Does the Check Engine light come on at all? My 91 accord would act like it was starving for fuel and would die when put into reverse and the cooling fans would spin backwards..Then the check engine light would come on and everything was fine.. Found it was bad brains [Ecu was dead] Try Replaing your Ecu with a junk yard unit and see if this helps with your problem..If it does then have fun..
Old Dec 24, 2009 | 07:41 AM
staudi24's Avatar
I forgot to write that I have already replaced it and it still occurs it only does that when I on the highway at high speeds. It doesn't sound like its starving for fuel it just sounds like its running high pitched and struggling
Old Dec 24, 2009 | 07:47 AM
staudi24's Avatar
Old Dec 24, 2009 | 11:51 AM
nus_dogg's Avatar
Hmm.. weird.
Old Apr 18, 2010 | 06:50 PM
Sharmag's Avatar
I don't know if this helps or not...I have a 93 accord lx with a 2.2l motor in it, my car started doing some of the exact things your experiencing about a year ago..Come to find out the ignition control module (ICM) was at fault, what gave it away was the jumpy tach...They are fairly cheap and are a common problem.
Eric
TheTix
Apr 20, 2017 12:25 AM
zane0996
Feb 19, 2014 07:29 PM
galen
Jul 6, 2010 11:20 AM
staudi24
Jan 31, 2009 02:44 PM
bmacobwn
Mar 21, 2007 02:17 PM
