sucking noise from intake filter.
ok, i bought a new blox intake manifold and the dude said it was for his b16a2 (em1). so i install it on my car using my ls throttle body cause thats all i have for now. ( well i have a b16a2 tb but i dont know how to wire up the map sensor)
now that the blox mani with the ls tb is installed in my car. its successfully started up and idles fine. but this there loud sucking noise from my filter..
i took my intake off and theres that hold inside the tb near the b.valve, i put my finger over it and it stocks but the car wants to die. what does that mean?? not a matching tb? tb gasket?
my old manifold (stock) had the ftiv or something like that, that the blox doesnt..
the sucking noise is anoyying and i was wondering how can i get rid of that.
if a matching b16a2 tb would do the job, how do i go about wiring the map sensor if the EF map has like 2 plugs on that bracket thing mounted on the firewall.
does it sound like your typical loud as *** b series intake at idle? or different. i can't find a vid of some one just strait idling their car or i'd show you what i'm talking about
post *****??? lol......... maybe its your throttle body letting in to much airat once?
post counts dont mean anything.
my car idle'd quiet with the obd1 b16 mani. with this blox mani installed it has this loud ""SSSSSSSSSS"" sound from my filter. its never done it before.
bunch of this dicks in has the time to talk **** and not even provide any information. if i knew, would i ask? immature bastards.
im no where near a post *****. all my post are useful information or me trying to help or asking for help. not those critisizing ppl or ones that post " LOL, Nice, IBTL GTFO"
edit:
does it sound like this (the idling noise not the reving):
http://www.youtube.com/watch?v=ZK70SBXP-6U
i always thought that's how intakes are SUPPOSED to sound, i wish mine made that noise...
With an aftermarket intake its goin to hiss, especially with an aftermarket intake manifold. The more air is being sucked in the more sound is going to be made.
If the hissing is coming from the filter, i wouldn't worry about it. If it's coming from a join (between the IM and TB or TB to filter piping) then you'd need to fix it.
It's normal though Dana.
mines a carb'd aem intake and the aem filter. in the video its that hssss sound but louder and its at idle not throttle. ill make a video.
this is the reply i was looking for not those dumbass replies above (not you DCRB) thanks!
dunno if you were talking to me, but that's just a random vid i found on you tube. my set up consists of an injen lower pipe from their CAI set up modified to attach to the factory air box, with a stock style paper filter till i can afford a real CAI. just clarifying it
I honestly LOL'd when I read the post and called my bro over to get a laugh aswell.
The noise is normal, youre sucking in alot of air.
Ask at the local meet spot to make sure though, tell everyone your problem lol
i put a skunk2 pro series on my b16a and it did the same aswell its fine...they are loud at idle and very lound under high rpms
did you install a new gasket between the throttle body?
did you install a new intake manifold gasket..are the all the bolts tight?
is you b16a2 stock? and no capped off vac lines?
can you post a pic or video that may help
It was a joke dude, your intake SUCKS.... GEt it? Sucks air??
LOL @ beansandrice.. nice dude..
But honestly... Its normal... My S2 mani makes a nice hiss sound too..
Then I hit the throttle and it almost WHistles through the filter. Dont worry about it man.
Like someone mentioned above. unless the sound is from between the head and mani, mani/throttle body or throttle body and piping.. dont worry about it..
