KYB AGX install help.
Old Sep 3, 2002 | 12:01 PM
EVIL Hx Coupe's Avatar
Default KYB AGX install help.
i just got KYB AGX shocks and i was wondering if i need to cut the bump stop that they come with before installing them. Thanks
Old Sep 3, 2002 | 12:18 PM
Mojo-Jojo's Avatar
Default Re: KYB AGX install help. (Boost Pressure)
When I got mine on two weeks ago they didn't come with a bump stop.
I put it on with H&R Sport springs, and the instructions for the springs said NOT to cut the stop.
The AGX shock is designed to be a sport capable replacement for the stock height.
Cutting the bumpstop really depends on the spring. If you're installing springs at the same time, check the instructions. If not, leave the stock bumpstop, or if your AGX's came with a bumpstop, use it, but don't cut.
Old Sep 3, 2002 | 12:29 PM
Default Re: KYB AGX install help. (Mojo-Jojo)
I'm using coilovers not springs.
Old Sep 3, 2002 | 12:30 PM
HondaIntegraLS's Avatar
yes cut it then.
vtec lude3
Oct 5, 2004 03:38 PM
Chief Brody
Oct 8, 2003 07:38 AM
ds2000
Sep 4, 2003 12:30 AM
Razor
Dec 18, 2001 07:06 AM
95civic
Sep 7, 2001 07:29 PM
