Failed Emissions with my b16a swap.... help me pass
Old Dec 23, 2009 | 06:12 PM
ninty7hatch's Avatar
Default Failed Emissions with my b16a swap.... help me pass
So, I have a obd0 b16a swap in my 91 crx si with a PR3 ecu. Everything is stock...header, intake, exhaust, cat....everything. I took my car to emissions (Maryland) and the cat and gas cap passed but my hydro-carbons were 290 and I failed because they were supposed to be at 200. How do/ can I lower my hydro carbons? Thanks in advance for ideas and help
Old Dec 23, 2009 | 06:24 PM
ykni's Avatar
Default Re: Failed Emissions with my b16a swap.... help me pass
ttt...
Old Dec 23, 2009 | 06:32 PM
HondaPartsHero's Avatar
Technical Hero
check your ignition timing, spark plugs, plug wires, cap, rotor, PCV valve, O2 sensors or worst case you may need a new cat. Make sure to take the test with a hot catalytic converter after driving for a while.
Old Dec 23, 2009 | 06:57 PM
Well, I have new spark plugs, wires, cap and rotor....I rushed to the emissions place and drove no more than 20 minutes though
Old Dec 23, 2009 | 07:07 PM
ap1 george's Avatar
Change your oil, run higher octane gas, and drive it awhile like HondaPartsHero said, the catalyst is most effective/efficient when it's hot.
Old Dec 23, 2009 | 07:13 PM
Yea I definitely think that I have to drive a while longer before I go next time. I did however do an oil change and put 93 octane in it the day before...
Old Dec 23, 2009 | 07:44 PM
radex7's Avatar
I failed recently for HC myself. If you search you will find out that high HC are caused by incomplete combustion thus checking timing, spark plugs, wires and dizzy as well as leaky vacuum hoses, is crucial, well I had done all that and it still failed. My problem was a leaky injector seals or TB gasket. After I replaced that my HC dropped by 50%! Check hoses!
Old Dec 23, 2009 | 08:09 PM
ykni's Avatar
is this for usdm only or can you smog a jdm obdo b16 as well ???
Old Dec 23, 2009 | 11:21 PM
BiG ChOr!Zo's Avatar
if you live in cali you can smog it but you definitely cant bar it...!!!
Old Dec 23, 2009 | 11:39 PM
ykni's Avatar
by smogin you mean the not legit way right ?excuse me im not a total noob but still a bit green ...
Old Dec 23, 2009 | 11:58 PM
you can take it to any regular smog check and pass the smog test with proper tune up and maintenance depending on if the smog tech actually wants to smog it and hope that you dont get popped by the 5-0...on the other hand a jdm b16a was never offered in a 88-91 civic/crx USDM vehicle and therefore doesn't qualify as a legal replacement motor and would never pass a state bar check...your best bet is to get a USDM b16 motor newer than your vehicle and bar it if you want it to be bueno...!!!
Old Dec 24, 2009 | 12:01 AM
ykni's Avatar
daaaam that sound expensive thanx bud ...
Old Dec 24, 2009 | 12:23 AM
if you want a clean b16a2 USDM motor hit up Lunalink because he is selling his and he is located in south central...!!!
Old Dec 24, 2009 | 01:13 AM
ykni's Avatar
im kinda strapped for cash right now homie so i think i'll just keep doing it my way till i can afford all that .thanx though ...
Old Dec 24, 2009 | 01:17 AM
xJDMB16x's Avatar
Thats the same problem that im having i cant find anyone to smog my jdm b16a
Old Dec 24, 2009 | 08:01 AM
Phatwhippin_CRX's Avatar
Know anyone with a V-AFC?
Could lean it out a little, would definitely help.... and definitely drive it around for a bit before you head over there.
Old Dec 24, 2009 | 11:53 AM
skipbudlong's Avatar
The v-afc will really help pass smog? Can anyone confirme this?
Old Dec 26, 2009 | 11:49 PM
ninty1civic's Avatar
this is my buddy whos car is failing emissions.. in maryland they dont give a **** what kind of motor you got in your car or if its a "legal" replacement or any of that bs.. all maryland cares is that it passes the emissions specs.. what do you guys think about this.. the a-hole, we call him ghetto garrett, who helped my buddy do the swap only ran one 02 sensor.. and supposibly pinned it into the ecu.. anywho, its right before the cat.. but im under the impression that there should be 2 and they should be right on the exhaust manifold.. yes or no.. also my question is will this make it run rich and or make the hydrocarbon reading higher? what do you guys think about throwing a fpr on it and dialing it down to lean it out?
Old Dec 27, 2009 | 05:22 AM
littlebluecrx's Avatar
pr3 ecu had different emision specs than the us spec p30's. I would make sure the swap is wired correctly. No codes, the 2 o2's, knock vtec, and pressure hooked up correctly. I would bump ignition timming up to 18 degrees, and make sure your tps is set properly. make sure all the evap stuff is hooked up right, pcv etc... But it also depends on the cat, how old it is, and what motor it was meant for.. If you have a 20 year old cat that might be the big issue.... Fixing the the above issues will definetly help. The single wire o2's take a few minutes to heat up, but if they are not working right you wont allways get a code.
Good luck....
Old Dec 27, 2009 | 07:03 AM
canadaek's Avatar
HC are unbured fuel - the higher the octaine level the slower the fuel will burn so 93 not good to reduce HC levels - . what where your othe reading's CO NOx CO2 i used to be a canadian emmsions repair tech so i don't know all the usa rules and regs but that high of level is usally a bad O2 sensor or Cat but a friends b16a had a bad tps sensor that caused ecu to think it was a wide open throttle when it wasn't good luck feel free to ask more ???
Old Dec 27, 2009 | 07:13 AM
Acura-Power's Avatar
Default Re: Failed Emissions.... help me pass
Add some Ethanol. If you can find where they sell E85 you can add a gallon. The second time you fill up add 2 gallons. I read that my Acura TL can run as high as 33% without setting off the O2 sensor. I run around 30% and my vehicle runs great, plus at 30% I am at 94 octane.
I have a simple formula. 85 (one gallon of E85) + 40 (4 gallons of E10) = 125 then divide by 5 (the number of gallons of total fuel). 125/5 = 25% ethanol. This will give you 93 octane too.
My acura TL is suppose to get 17 city and 27 highway and I have gotten as high as 35.98 mpg on the highway when I hypermile.
Old Dec 28, 2009 | 07:55 AM
EFWhite's Avatar
Just took my 91 EF in to get tested for the first time today and it failed the NOx. Running at 1700ppm, max allowed ~1100ppm. From what I've read so far I'm probably running too lean. It has an after market intake (cone) and a custom header. Stock muffler and stock cat. I'm thinking that the intake is causing it to run lean, but I'm not sure how to fix it. Any suggestions? I'm going to pull out a plug to see if the engine is running hot to see if it is running lean, I'm also going to try to pull the O2 sensor and see if it looks damaged at all.
Any other thoughts?
Old Dec 28, 2009 | 10:39 AM
CRX T-Si's Avatar
can't an older cat cause higher levels of HC? Some pores inside may be slightly clogged..just sayin.
If you need a fuel controller I have an older Field fuel controller that I am willing to let go of $40 bux shipped.
Old Dec 31, 2009 | 08:12 AM
Thanks for all of the ideas. I need to stop being lazy and mess with my car. The only thing I dont really want to do is use ethanol
Old Jan 20, 2010 | 08:17 PM
