Integra / Civic Parts.. D16y8 Parts
97 Civic...
-OBD2a 5spd P2P ECU... $30
-D16y8 OBD2 Intake Manifold {TB, 1 mnth old IACV, All Sensor}...$70
-D16y8 OBD2 Altenator... $50
-D16y8 Axles.... $80
-D16y8 Clutch Set w/ Flywheel (mint).... $70
-D16y8 Shift Linkage... $50
-D16y8 Distributor {1mnth old}... $150
-D16y8 Starter...$50
-D16y8 Power Steering Pump... $50
-D16y8 Back Tranny Bracket... $20
-D16y8 Complete Shortblock {121k miles, block started to knock. Still runs, No bent rods. New timing belt, rear main seal, water pump, head gasket done about 8mnth ago..All oem, Head was resurfaced and pressure tested as well}.... $150
-EK Passanger Side Door Panel.. $30
Integra...
-B18b1 OBD2a Wire Harness... $80
-B18b1 OBD1 Altenator... $50
-B18b1 A/C Bracket... $20
-B18b1 A/C Compressor... $60
-Black Glove Box... $20
-GSR Black Leather Arm Rest... $40
-LS Black Arm Rest... $20
-LS Graffitti Grey Passanger Door Panel... $20
-DC Subframe w/ Power Steering Rack {need new boots}... $100
-DC 5spd Pedal Assy. ... $100
-DC Clutch Master Cylinder... $40
Integra...
