trunk leak
sorry i used my iphone camera =(
do you guys think its coming from the seals on the top of my trunk cause theres like a trail of water going down
plus it ****ed up my trunk keep saying its opened and my compustar alarm kept going on saying my trunk is open
i have a 95 integra gsr
usually a trunk leak is caused by a tail light gasket or sunroof drain being blocked/clogged or disconnected. to diagnose your drain tubes remove the side panels and visually check them. the tail light gaskets are probably bad either way. as for your hatch light, its possible the switch is bad, i do not know where the switch is at.
i had a trunk leak on my DA, and once i replaced my tail light gaskets it went away. if you cant find the leak, you can try driling a few well placed weep holes in the trunk floor to drain the water. thats what i did as a temporary fix and it worked great. but if you choose that route, make sure you prime and paint the holes to ensure it doesnt rust from the water.
sil04ver
Nov 18, 2008 06:35 AM
Cuong-nutz
Feb 24, 2005 05:16 AM
