help with my ek fuel issue
Old Dec 23, 2009 | 09:10 AM
briEK's Avatar
New User
Default help with my ek fuel issue
please help we went out to eat the other night and when i parked the car turned off...
the motor turns over normal, the fuel pump doesnt go on soo..
changed the main efi relay did nothing...
the car had a fuel cutoff switch for security, took it out and returned to stock to try and solve the problem and nothing..
any ideas whats next??? new ecu? or melted wires? or new fuel pump? or any other ideas
thanks for the help
Old Dec 23, 2009 | 09:28 AM
Former User's Avatar
Default Re: help with my ek fuel issue
Check fuses 13, 31, and 44.
Run power directly to the fuel pump. If it doesn't run, check its ground wire and, if good, replace the pump.
Clean and tighten the ground on the thermostat housing.
Check the ignition switch.
Old Dec 24, 2009 | 07:36 PM
briEK's Avatar
New User
fuse 13 thanks, dont have the panel to check helped alot!!!
NovaRex
Jan 27, 2016 06:59 AM
koffeedc2
15
Feb 10, 2015 03:56 PM
jianwa
Jul 31, 2010 02:03 PM
cticknor666
Apr 3, 2010 08:32 PM
WavyIntegra
Jan 1, 2010 01:57 PM
