Cutting Reliefs on Head Flange
Old Dec 23, 2009 | 07:26 AM
jjspec's Avatar
Default Cutting Reliefs on Head Flange
How beneficial is it to cut reliefs on a head flange and would you do it after welding the entire header?
Old Dec 23, 2009 | 07:31 AM
90blackcrx's Avatar
Default Re: Cutting Reliefs on Head Flange
Yes, it should be one of the very last procedures you do, after milling the flanges flat. It does help, is it drastic, who knows. Some companies do it, some don't , the companies that don't do it don't seem to have a problem either.
Old Dec 23, 2009 | 07:48 AM
91jdmhatchback's Avatar
90blackcrx pretty much nailed it. It is kinda a do it if you want thing in my mind. I have never cut a flange and don't plan on doing it any time soon. It is a looks thing in my book, and i have never had a warping issue or cracking issue from flanges pulling or warping.
my 2 cents
Old Dec 23, 2009 | 08:02 AM
weiRtech's Avatar
OG Fabricator
read maximum boost. it discusses manifold building a bit. it says to split the flange. it also says to weld only the inside of the runners at the flange. it also says not to wrap your manifold.
bottom line: everyone usually does things how best works for them. personally, i don't split the flange, and i weld inside and out at all flanges.
Old Dec 23, 2009 | 09:38 AM
jjspec's Avatar
Thanks for the responses. I have seen them both ways and was just wondering.
Old Dec 23, 2009 | 10:13 AM
Agtronic's Avatar
I like the idea of splitting flanges on really thick flanges, but am scared that the stress found in the runners may mis-align the ports.
Old Dec 23, 2009 | 10:16 AM
CoreyR's Avatar
this
if your runner warped/shrunk even a little after welding it to the head flange, when you make the cut on the flange its going to misalign the flange sections.
Old Dec 23, 2009 | 11:49 AM
90blackcrx's Avatar
Originally Posted by CoreyR
this
That's why the flanges need to be milled or sanded flat first, if you do this it won't be an issue at all.
90blackcrx's Avatar
Such a great book.
Old Dec 23, 2009 | 12:06 PM
dave@passenger's Avatar
Maximum Boost is hands down the worst turbo charging book on the market as far as information goes.
Old Dec 23, 2009 | 12:09 PM
CoreyR's Avatar
not necessarily. im talking about it moving up and down to the point where it wont match up the the bolt pattern because one port is lower then the one next to it. ive seen an instance of that before.
Old Dec 23, 2009 | 12:14 PM
weiRtech's Avatar
OG Fabricator
how about splitting the flange only half way, or say 3/8" through on a 1/2" flange? i know some of the vw flanges i sell have a slot down between the ports, but not split all the way through.
dave, can you give any particular reason why? although dated, i find some of the info in it is still applicable.
Old Dec 23, 2009 | 01:30 PM
9295EJ-t's Avatar
Such a great book.
i lol'd a bit... ha ha!
Old Dec 23, 2009 | 01:34 PM
I do something similar, to disperse heat quickly, to help deal with thermal displacement, I would not recommend welding a manifold together using a solid head flange and than dividing the ports on the flange afterwards, you are asking for some serious mis alignment, unless of course you are dowling the flange to the head, but honestly, how many here actually do that?
As for maximum boost, I couldn't accurately quote any text off the top of my head as its been a few years, but from what I remember virtually his entire chapter on exhaust manifold design was poor, everything pertaining to volume and flow rates down to fabrication techniques I remember being weak and in many cases flat out wrong.
Old Dec 23, 2009 | 08:08 PM
Agtronic's Avatar
What I mean is that the ports are very likely to move in every which direction once you split them at the flange. Making the flange 100% flat before cutting will not prevent this from happening. My manifold flanges come off the jig and always straight, but I'm pretty sure it would be a disaster if I decided to cut the flange between the runners. That's why I like adding a slot between cylinders, like this : (I did not design that flange)
Alternatively, you could cut the flange between the runners before welding the manifold, and make sure you have a good solid fixture, but even then I don't know how straight it would stay ...
edit : changed the pic
Old Dec 23, 2009 | 11:01 PM
CRMB's Avatar
OG Fabricator
Seems to work ok if the header has been fully stress relieved. It's a complete disaster if you weld up a header, pull it out the jig and start sawing away between the runners tho.
Old Dec 24, 2009 | 05:27 AM
weiRtech's Avatar
OG Fabricator
don't take this the wrong way, but if you can't back up a statement, why make it? please take the time to point out what you disagree with specifically, not just generally... "flat out wrong" is a pretty strong statement i think. i think much of it still holds water when designing/building a manifold.
i would appreciate your opinion/knowledge/experience that opposes someone who has published a book about the subject. i know things have changed a lot since that book was published, and i would like to know what works best for other people too. (sorry for the thread jack).
Old Dec 24, 2009 | 08:10 AM
No offense taken, I have a copy of the book somewhere, I will find it, and make a couple points to you. And I hope you don't think that because someone published a book about something means its content is true or accurate.
Old Dec 24, 2009 | 08:46 AM
Leebro61's Avatar
It's a pretty generic book that some how became gospel over the years. I think it's a good fundamentals book if you don't have a background in the subject, but past that probably not worth the credit it's given...
Old Dec 24, 2009 | 08:58 AM
RC000E's Avatar
I think that with the time involved in manifold building and competitive pricing as it is, that adding another procedure that certainly hasn't proven its worth is just wasted time. Full Race did it and others that "wanted to be like Mike" did it too.
With mild flanges it certainly doesn't seem to be of any benefit, and there's more manifolds out there without it done than with. With stainless flanges, maybe there is some benefit due to the characteristics of stainless, but noone really uses stainless flanges for manifold purposes except for ching chong meows on ebay.
Old Dec 24, 2009 | 09:05 AM
Agtronic's Avatar
Hey Aaron, that's not very nice! I use stainless flanges almost exclusively! :D just messin'
Old Dec 24, 2009 | 09:09 AM
My thoughts exactly.
Old Dec 24, 2009 | 09:56 AM
weiRtech's Avatar
OG Fabricator
no, i don't think, just because it is in a book it is martial law or something. i just want insights as to what works for different people, and to discuss why one method has advantages over another and vice versa. i'm always trying to improve my own knowledge and skills. i don't think anyone should think they've reached a pinnacle that is unattainable by others. that is just setting yourself up for a fall. no amount of reading or research can measure up to first hand experience.
like i said in my initial response to this thread, bottom line is: everyone does what works best for them.
Old Dec 24, 2009 | 12:18 PM
jjspec's Avatar
So, what would be the best way to stress relieve the runners after welding? That would seem to be a good idea even if you dont cut the flange. Seems like it could help alieviate some stress cracking possibly.
Old Dec 24, 2009 | 12:43 PM
CTD-Fab's Avatar
I have seen many manifolds that were straight and flange cut, go through heat cycles and get completely wacked out.
But bottom line, gaps create stress and pulling, no gaps - no stress. Take some pride when tacking everything and you will find things will go 100% smoother down the whole production line.
