5.0 throttle body on a honda?
Old Dec 23, 2009 | 06:43 AM
B SERIES US's Avatar
Default 5.0 throttle body on a honda?
I need to know what is all needed to install a 5.0 t/b on my intake-(gato racing).I need to know how to wire in the ford tps if possible,and what do i do about the throttle cable? Thanks for your help.
Old Dec 23, 2009 | 09:10 AM
gator88's Avatar
Default Re: 5.0 throttle body on a honda?
If you need to ask you will probably bitch it up. This is also one of those things that not many people have done, so for once you may actually need to be the first to experiment with your time and money. There isnt a write up out there for everything...
My question is why are you wanting to do this?
Old Dec 23, 2009 | 10:06 AM
89s1's Avatar
X2 on why do you think you need it.
What engine is it, what's the setup?
You don't give us much to go off of in your original post.
Old Dec 23, 2009 | 10:45 AM
OK lets try this again,The Gato racing intake manifold has the bolt pattern for a ford 5.0 t/b,the reason why is because it has a 80mm t/b bore,it is for a boosted engine and there are not many companies that make honda 80mm t/b,so with that being said i am just woundering who has done this type of set up with the ford t/b on a honda
Thanks
Old Dec 23, 2009 | 12:12 PM
4g4dcruisin's Avatar
Thanks
is the pulley for the throttle cable in the same position as a honda?
just do it and post pics whats the situation? i've never heard of that but if that IM you have will bolt up to whatever head you have, then also accept a 5.0 mustang TB then go for it!
it seems like the only thing u have to worry about is the throttle cable location. post pics!!!
ScareCrow92
Feb 21, 2016 11:04 AM
conquer11s
Feb 9, 2007 02:19 PM
billyrocka66
20
Mar 21, 2006 05:57 PM
DXK Eg
Dec 19, 2004 09:50 AM
lilbill3554
Jan 28, 2004 07:39 PM
