ARP rod bolts, machining required??
Old Dec 22, 2009 | 08:36 PM
TheCrimsonGhost666's Avatar
Default ARP rod bolts, machining required??
Alright, im rebuilding my ls and im using arp rod bolts for a little extra security. Some people say you have to machine the rods if you use arp rod bolts, and some say they are oem replacement, just stronger, so no machining necessary. I want a straight answer to this question.
Old Dec 23, 2009 | 05:51 AM
kyden's Avatar
Default Re: ARP rod bolts, machining required??
need to machine.
Old Dec 23, 2009 | 09:15 AM
What specifically needs to be done, and how much does it cost?
Old Dec 23, 2009 | 09:56 AM
Scott_Tucker's Avatar
It shouldn't matter but you should have them check for proper inside diameter as rods tend to go oval shape in service.
Old Dec 23, 2009 | 11:17 AM
Mikey3000's Avatar
they're probably saying that because you use a slightly higher torque value on the rod bolts which may distort the big end. i don't think many people do this though so you should be fine w/o machining. now if you use the high grade bolts that are torqued to a higher value then you really should get the rods measured with the bolts torqued.
Old Dec 24, 2009 | 10:03 AM
MatrixGSR's Avatar
I'm doing the same thing with mine. Since you are not removing any more material from the end caps or rod - you are fine. There will not be any need to machine. You can get a flex hone for the rod end to make sure you have a clean seat or use some scotch brite.
Old Dec 24, 2009 | 01:15 PM
bks84's Avatar
Loved
My machinist specifically told me there is resizing/reconditioning required after installing the rod bolts. Its not just in honda apps, its also required on all rods; BBF, BBC, SBF, SBC, Mopar... doesnt matter.
After they're installed/pressed in the big end then becomes destorted. They grind (line hone) the big end to make sure its round, not oval and within spec.
Old Dec 24, 2009 | 02:08 PM
MatrixGSR's Avatar
I won't argue that - but would someone not be able to do this themselves? I know my block had to have the caps cut and align honed. I had ARP main studs and there wasn't any distortion. I would assume the same procedure could be done with a set of honing stones.
There's some stuff on here
http://www.popularhotrodding.com/eng...bly/index.html
Old Dec 24, 2009 | 02:24 PM
bks84's Avatar
Loved
Its not something I would trust myself to do, so I'm going to say no.
SOHC_me
Nov 7, 2006 02:05 PM
turbociv
Sep 8, 2003 05:41 AM
untitled
Jul 2, 2003 11:25 PM
FastFoot
Sep 28, 2002 12:09 AM
2020ls
Aug 20, 2002 03:38 PM
