EF Partout
Old Dec 22, 2009 | 07:30 PM
matt17249's Avatar
Default EF Partout
Engine -
B16A1 W/ Y1 transmission - Have owned for 4-5 years but only driven in summers and about 5K miles total
Timing belt, water pump, thermostat, spark plugs, wires, etc.....
Exedy stage 1 clutch kit w/ lightweight flywheel and pressure plate
ARP head studs, Honda N1 light weight crank pulley - $2000
-T3/T4 Turbonetics turbo - $1000
-Hasport motor mounts $100 ------SOLD
-hasport shift linkage $75---------SOLD
-hasport axles $200 -------SOLD
-RC saturated 650cc injectors $300
-OBD-1 conversion
-OBD-1 guts of dist in a pre obd-1 dist body $200
-OBD-0 to OBD-1 ECU conversion harness $100
-P28 ECU Socketed w/ Hondata S300 $1000
-P75 ECU - Stock 94 integra B18B1 Auto trans $80
-PW0 ECU - Stock B16A1 OBD-0 Goes with engine if not sold with turbo
-PM9 ECU - Stock 91 Civic Hatch DX Manual trans $50
-PLX wideband O2 sensor w/ Display $200
-Skunk 2 intake - $200
-Skunk 2 CAT back exhaust - $300
-Peak and hold injector resistor block - $15
-B series clutch cable $50
-B series throttle cable $50
-Harness i made for B16a1 in EF chassis - $80
-EG radiator (hole repaired) - $30
-Hasport sub harness $50
-Stock B16A1 intake manifold - goes with engine unless sold otherwise
-Brand new never used 1991 civic SI engine harness from honda(not pictured) - $200
-No name sequential BOV - $40
-Turbonetics Evolution Wastegate - $200
-Intercooler - 3.5" thick, 8" tall, 28" wide - $100
-3-Bar MAP sensor GM - $25
-Electronic speed sensor for Y1 trans, came with trans but never used it due to cable cluster - $40
-Stock B16A1 injectors - goes with engine unless sold otherwise
-OBD-0 Stock B16A1 distributor - goes with engine unless sold otherwise
-OBD01 distributor USA modified to fit b16a1 -$150
-New oil pan gasket set any D-series engine - $10
-New 2 sets of valve stem seals B16A - $10 each
-New 2 intake gasket B16a - $10 each
-New B16A valve cover gasket set - $20
-2 EG radiator fans - $30 each
-1 EF radiator fan - $30
-2 EF A/c Fans - $25 each
-2 EF under hood fuse boxes - $15 each
Suspension -
-Tokiko Illumina 5-way adjusting shocks with 1.25 drop springs - $200
-Front upper control arms with camber adjusting ball joints - $120
-Rear upper camber adjusting control arms - $80
-All four lower control arms with polyurethane bushings - $50 each or 150 for all
-2 Stock upper control arms with ball joints - $30 each or 50 for pair
-Front knuckles w/ calipers, rotors, pads - $100 each or 160 for pair
-New front right outer tie rod end - $20
-Front upper strut mount brackets for a strut tower bar(no bar) - $20
-Front crossmember to fit EG radiator in EF chassis - $120
Brakes -
-Rear disk conversion from 90 integra $300
-Rear trailing arm bushings replaced w/ polyurethane
Interior - all interior parts for and EF hatch unless noted
-98 civic cd/radio with harnes to plug and play with EF chassis - $50
-Interior clock - $20
-gauge cluster with TACH 247K - $50
-CRX SI steering wheel - $50
-Headlight and wiper control switches from column with turn switch return - $25
-New electrical portion of ignition switch - $40
-Speedo cable - $35
-Glove box (blue) - $20
-Interior fuse box cover(blue) - $10
Exterior - all exterior parts from an EF hatch
-Right and left headlamp assemblies EF - $25 each or 40 for set
-Right and left side corner light assemblies - $15 each or 25 for set
-2 left side mirrors - $30 each
-1 Right side mirror - $50
-2 left side tail lamp assemblies - $30 each or 50 for a set
-2 right side tail lamp assemblies - $30 each or 50 for a set
-4 wiper arms with blades 2 pass 2 driver - $20 each or 30 for set
-wiper motor - $30
Misc -
-Walbro 255lph high flow fuel pump in sending unit for EF - $100
-Wheels - Motegi 17X7.5 rims with Yokohama parada spec 2 215/40/ZR17 w/ about 7/32" - $400
-Skunk 2 short throw shifter - $60
-Factory 88-91 civic service manual from honda - $50
-Factory manual for JDM 88-91 civic w/ supplement for B16A1 - 80
Check out my pics and call for anything that you have questions about.
http://i576.photobucket.com/albums/s...t/IMG_1062.jpg
http://i576.photobucket.com/albums/s...t/IMG_1044.jpg
http://i576.photobucket.com/albums/s...t/IMG_1045.jpg
http://i576.photobucket.com/albums/s...t/IMG_1046.jpg
http://i576.photobucket.com/albums/s...t/IMG_1050.jpg
http://i576.photobucket.com/albums/s...t/IMG_1051.jpg
http://i576.photobucket.com/albums/s...t/IMG_1052.jpg
http://i576.photobucket.com/albums/s...t/IMG_1058.jpg
http://i576.photobucket.com/albums/s...t/IMG_1060.jpg
http://i576.photobucket.com/albums/s...t/IMG_1061.jpg
http://i576.photobucket.com/albums/s...t/IMG_1065.jpg
http://i576.photobucket.com/albums/s...t/IMG_1067.jpg
http://i576.photobucket.com/albums/s...t/IMG_1068.jpg
http://i576.photobucket.com/albums/s...t/IMG_1069.jpg
http://i576.photobucket.com/albums/s...t/IMG_1070.jpg
http://i576.photobucket.com/albums/s...t/IMG_1090.jpg
http://i576.photobucket.com/albums/s...t/IMG_1092.jpg
http://i576.photobucket.com/albums/s...t/IMG_1094.jpg
I am probably forgetting lots of stuff, will update when as i remember what im missing
Am open to offers but SERIOUS ONES ONLY.
Cell - 612-964-9227 -ask for Matt
Email - mt17249@gmail.com
Calling is the best way to get ahold of me, i go days without checking email sometimes
Thanks for looking!
vw40life
Apr 20, 2012 05:09 PM
93grayeg
Mid-Atlantic (Sales)
15
Aug 19, 2011 05:41 PM
lsvtec hf
Engine Management and Tuning
Jan 21, 2009 12:02 PM
D16SiHatch
Mar 3, 2008 08:48 PM
MugenMaster
Feb 25, 2008 09:33 PM
