Rear Toe maxed out on DC trailing arm?
So I recently had the car aligned, turns out they could not get the toe setting on the driver side rear traling arm. Anyone with experience or similar issue? I was told maybe a bent frame, but I have recently replaced the trailing arm bushing on that side since it was torn. Hopefully a bent trailing arm or toe arm. Any info would help, thanks
also, car is dropped on H&R Oem sport 3/4 inch front and back on koni yellows
yes DC integra. and yes compensator toe arm. and yes when I installed the bushing I did it per OEM Acura manual. hm.. maybe the compensator arm is bent.
yes, its very likely trailing arms are bent, but if theyre original then you shuold know why....
and if you dont have a DC, you shouldnt be using the DC toe arms.
