95 Civic Ex/Si Rear trailing arms
I have a set of rear trailing arms from a 1995 Honda Del Sol SI. These will bolt on to your EF or EG Chassis. They are in good working order. I was going to install them on to my 89 Civic Si hatch, but decided to mod my motorcycle instead.
The RTA's have rotors, pads, calipers, e-brake cables, rear brake hoses ($200). I don't know how much life if left on the rotors or pads, but there's enough on there to not have to worry about it for awhile.
I also have a 4040 prop valve for $35. If you buy the RTA's and want the valve, you can have it for $25.
I will be able to meet you after 7 this evening inthe 925 area code (Pleasanton, Dublin, Livermore)
KEY WORDS: 4040, 40/40, prop, prop valve, SI, Civic, del sol, rta, honda, eg, eg6, ef, ef9, 88, 1988, 89, 1989, 90, 1990, 91, 1991, brakes, conversion, vtec, d16, a6, z6, y8, d16a6, d16z6, d16y8, b16, b16a
turboblack2door
Jun 27, 2010 08:17 AM
