Stalled out
Old Dec 21, 2009 | 07:57 PM
rhdcivic05's Avatar
Icon6 Stalled out
I have a 95 accord wagon lx. i have just swapped the jdm h22a into it and i just got everthing put in and together. i have up and down surgeing going on and i got two ck engine codes. 1 and 14. i just got the o2 sensor and put it in the exhaust so im not sure why there is a code for it.... and i found one vaccume leak and when i plug the hole the motor stalls. i am racking my brain and could use some info if anyone has any clues!!!!
Old Dec 27, 2009 | 10:38 PM
SmokeV-tec's Avatar
Default Re: Stalled out
hey, i had the same problem on my H22 when i got done building it. it flared from 1k to about a little past 2k. it also died when i plugged up my vacuum leak, is the leak coming from behind your intake? I also had another problem that was the reasoning of my idling, check your Idle Air Control Valve. it located right under your intake. after you take it off, get some boiled water and place the IACV in it and see if it retracts. let me know your progress
boredumb
Jun 11, 2011 05:15 PM
frathouse87
Sep 13, 2007 08:04 AM
duceducecord
Dec 21, 2006 08:34 PM
Metal Head
May 31, 2006 10:59 AM
93HONDAACCLUDE
Mar 19, 2005 05:05 AM
