1991 CRX CEL codes (searched)
Old Dec 21, 2009 | 02:21 PM
90RENOsedan's Avatar
Default 1991 CRX CEL codes (searched)
the car is throwing an 8, and a 16.
i know what the codes mean, one is for fuel injector, the other is for tdc position.
thats what gets me, is it pointing out a sensor? a cam sensor? crank sensor? is there a tdc sensor?
its not my car, its a friends. i know how to fix it, i just need to know what to replace.
and to reset the ecu, is it just undo the battery cables for 10 seconds, then put them back on?
Old Dec 21, 2009 | 02:50 PM
D16SiHatch's Avatar
Default Re: 1991 CRX CEL codes (searched)
tdc code is for the tdc sensor inside the distributor
Old Dec 21, 2009 | 02:59 PM
ok, thanks thats what i thought.
Old Dec 21, 2009 | 08:12 PM
ilikericedotcom's Avatar
just some fyi on that tdc sensor.. dont try to replace the actual sensor like i did. i think its calibrated into the distributor. i had a know working dizzy and tried replaced the guts on it to save 300 bucks on a new one. i adjusted that sensor prob 50 times with same code. borred friends dizzy and vanished. i dont mind spending money on a part if it needs to be replaced, but i must have replaced my dizzy once a year it seems like. quite annoying.
Old Dec 21, 2009 | 10:14 PM
thanks, i'm not gonna try to replace just the sensor.
mods, you can lock this thread now.
sgull
Feb 25, 2013 05:32 PM
Lavid2002
14
Jul 3, 2012 01:46 PM
Jagan'92
Jun 10, 2004 07:43 AM
quik89
Nov 30, 2003 06:43 PM
Eluzion
Jun 20, 2003 12:08 PM
