1995 Acura Integra GS-R Stuck At Cold?
Old Dec 21, 2009 | 12:06 PM
Shutweld's Avatar
Default 1995 Acura Integra GS-R Stuck At Cold?
Hello guys,
I just purchased a '95 Integra GS-R. And for some reason, the temperature gauge will not move. It just stays at cold. What could be causing this? I was told by a guy at Autozone that it could be the thermostat...?
And also, another problem. When I hit the wiper to spray the windshield washer fluid, it sprays, but the wipers don't move. But if I turn the wipers to the on position, they will then move.
Thanks for the help.
Old Dec 21, 2009 | 12:17 PM
Spawne32's Avatar
Default Re: 1995 Acura Integra GS-R Stuck At Cold?
the wiper spray is normal, push down and pull towards you, cus there are two different actions on the trigger handle for both different things, as far as the car not warming up, does the engine get hot? How about the radiator hoses? Radiator, heat in the car? etc etc. If you have all of thee above, you probably need a new coolant temp sensor.
Old Dec 21, 2009 | 12:19 PM
mouab18c1's Avatar
try bleeding your coolant system first before replacing anything
Old Dec 21, 2009 | 12:40 PM
Shutweld's Avatar
thanks for the reply
It does throw out hot air, so I guess I will try the bleeding method first before I replace that sensor.
I will do that. Thank you!
VenomRx
Nov 16, 2013 03:13 PM
Acurasforlife
Aug 31, 2011 03:03 PM
cmhuber90
May 22, 2011 12:20 PM
gsrb18cswapguy
Nov 7, 2004 08:04 AM
PDXHatchback
Nov 24, 2003 07:27 AM
