ac turns on and off
i have a 89 Honda crx hf, and i had the problem with the climate controls that split in half. i fixed that problem by swapping it with a 94 civic hatchback climate control. after fixing this problem a new problem came up. the compressor kicks on and stays on but the air will turn on and off on certain settings for example when the upper vents are turned on i hear a clicking sound and then it turns off then another click turns on.
i had a friend that said it was the something doors are jammed. were are these found in the car? and it a easy thing to fix?
maybe the blower motor resistor wires are disconnected, touching and untouching over and over again.
the doors are found all over the place in the car haha, take the dash board off and ull see them all.
