Tailights and dash light.
When I turn on my headlights, usually my dash lights and the position lights at the rear will light up, but now the tailights and dash lights won't come on. But it's weird because when I press on the brake, my dash lights and tail lights will come on. Anyone have an idea on what could be the problem?
Thanks
Thanks
in that case , i think your electrical wire is touching each other causing fuses to blow. check your radio wire, your wires behind your guage cluster. THis happened to me once, The fuses for the taillight.parking/and interior light would blow each time i turn it on and my signal would go off each time i honked the horn!..then i checked mah wires, and there it was touching each other and melted each plastic that was covering it just retape or change out the wires. HOpe this helps...1ne
OneZero1010101
Jun 10, 2004 05:19 PM
