Skunk2 Throttle body sticking ?
Old Dec 20, 2009 | 08:20 AM
mattsterling15's Avatar
Default Skunk2 Throttle body sticking ?
hey guys this is my first honda ..yay .. its a 99 civic with a h22 from a 01 prelude sh
so heres the deal
the car runs funny .. like it will idle at 600-700 and run like **** and will have a check engine light on which is the IAC .. i replaced that and nothing changed
well heres the funny part
I can start the car and hold the gas down and the car will idle at 1300 or so and run perfect no codes nothing
is my throttle messed up ?
its a skunk2 and ive heard bad things ?
Let me know what ya think
Old Dec 20, 2009 | 09:20 AM
king06's Avatar
Default Re: Skunk2 Throttle body sticking ?
Get a stock one and replace it.
But it sounds like your TPS maybe out of wack.
Old Dec 20, 2009 | 12:29 PM
A Blue Lude's Avatar
Skunk throttle bodies are garbage.
Old Dec 20, 2009 | 02:23 PM
su8854's Avatar
plug in something in the obd2 (i used mac tools code scanner) that will show you the throttle position. then take out the two screws out of the tps and keep rotating it until you get 0% throttle position. you may not beable to bring it all the way down to 0, i was stuck at 10% and was able to lower it almost to 4%. drives nice now. my idle is at 1000 and it has alot of rumble too. im using the skunk2 pro series intake manifold
Old Dec 20, 2009 | 02:25 PM
su8854's Avatar
also make sure you dont have bubbles in your coolant from taking out the lines out of the stock throttle body
Old Dec 20, 2009 | 10:15 PM
gstrudler's Avatar
Don't forget to set your base idle speed (I'm assuming you can do this on the s2 tb's like the stock ones). Unplug the IACV and the car should still idle at around 500rpm iirc (make sure you've jumped the 2P service connector first).
Vladimir Kanev
Oct 14, 2014 01:01 PM
slowEGles
Apr 6, 2014 03:39 PM
Romo Pyro
Apr 20, 2010 07:50 AM
tgh22a
Mar 19, 2005 03:43 PM
tgh22a
Mar 13, 2005 12:47 PM
