P1491 code on 99 Honda Accord
Old Dec 20, 2009 | 06:32 AM
AstacioSantiago's Avatar
New User
Default P1491 code on 99 Honda Accord
I have a Honda 99 Accord. I have two codes P730 and P1491. The drive train does not change beyond 2nd gear. Can anyone give a lead on where to start .
Old Dec 24, 2009 | 11:20 PM
PilotOnDubs's Avatar
Default Re: P1491 code on 99 Honda Accord
is your accord a v6?
P1491 insufficient EGR lift. pretty much you have to replace the egr valve and if it's a v6; you have to remove the intake manifold and drill/clean out the egr port to remove carbon build up. honda has a repair kit for this problem for v6's
P0730 Problem in Shift Control System
i think you should fix the egr problem 1st as its possible that it may have contributed to the P0730 code.
Best Of Luck
Old Jan 4, 2010 | 02:15 PM
New User
My Honda Accord is a 4 door, 4 cylinder model, automatic tranmission.
Sandra Wilson
Mar 15, 2018 12:39 PM
Alfredo1952
Oct 11, 2017 06:49 AM
Qi Jiang
Jan 28, 2017 07:25 PM
golmal007
Jun 18, 2013 04:29 PM
