B16 hydro to Civic 91
Old Dec 19, 2009 | 09:03 AM
Bc3's Avatar
Bc3
Default B16 hydro to Civic 91
if i am going to buy this kit
http://cgi.ebay.com/B-Series-B16-B18...item3a55e0019c
and this kit
http://cgi.ebay.com/ebaymotors/Ef-88...Q5fAccessories
will b16a2 engine and hydro trans fit in my Civic ?
Alli
Old Dec 19, 2009 | 09:12 AM
crx_si-r's Avatar
Default Re: B16 hydro to Civic 91
They will work but you are still missing the cable-to-hydro conversion bracket that sits on the front side of the transmission. This bracket converts the pullincg motion of the cable into pressure for the slave cylinder that pretty much attatches to the shift fork, making it shift.
Old Dec 19, 2009 | 09:13 AM
iheartteal's Avatar
yes but you will also need this
http://hasport.com/store/index.php/a...ch/efbhcl.html
Old Dec 19, 2009 | 11:32 AM
Bc3's Avatar
Bc3
i have this hasport cable to hydro converter
is it 100% that this will fit? ss the motor mounts
Old Dec 20, 2009 | 06:01 AM
94EG8's Avatar
Seagull Management
Or you can also swap the everything from the B16 tranny into a '92 - '93 Integra Cable case. Note that it must be from a '92 - '93, '90 - 91 wont work.
Old Dec 20, 2009 | 03:16 PM
bryse68's Avatar
and this kit
Alli
those mounts suck @ss. doesn't fit properly. please dont get the cheapest mounts off ebay. your better off with innovative mounts or hasports.
Old Dec 20, 2009 | 03:58 PM
beansandrice's Avatar
I disagree. I just used those exact same mounts on a CRX with a LS (B18B1) engine with no problems at all.
Just an
FYI. The engine should be installed loose into the engine bay then all mounts should be tightend little by little.
Jaydb1
Sep 23, 2016 07:30 AM
scspeed
Transmission & Drivetrain
Mar 8, 2009 06:55 PM
Bc3
Jan 13, 2007 04:19 PM
aser1z
Oct 4, 2006 11:08 PM
ysrhatch
Feb 17, 2002 06:48 PM
