LSVTEC, PCV valve?
ok. im just curious. my pcv valve goes no where. it goes down from the intake manifold and just sits there under one of the runners. theres no black box on the block. is there anything wrong with that?
is there anything wrong if pcv valve was removed?
its been like that on my lsvtec for 1 year now..it bugs to see it dangling there.
Not unless you are a hippy :D (first line in link)
http://www.aa1car.com/library/pcv.htm
Now you can answer a question for me. Since I've never removed a PCV "black box" what do you have on the block instead?
My guess would be that it won't really affect anything because you would have seen a side affect a long time ago. What year is your block? I have a 95 b18b and i just swapped the black box from my old 90 b18a block onto it, so you should be able to do the same
K i l l a B e e.
Mar 4, 2009 10:31 AM
