name that cel
Old Dec 18, 2009 | 09:25 PM
dmeconitas's Avatar
Icon2 name that cel
How do I read this cel? I have a obd0 pm6 but I read it as one long flash and 6 short ones but from my understanding obd0 is all short. So any helpful in site will be greatly appreciated.
Old Dec 18, 2009 | 09:37 PM
~sp33~'s Avatar
EFB055
Default Re: name that cel
I can only see one long and five short flashes. So i'd read that as a code 15. Ignition Output Signal.
Does the car start? What problems are you having?
Old Dec 18, 2009 | 09:38 PM
BiG ChOr!Zo's Avatar
you got a code 15 only...!!!
http://ef-honda.com/ben/ECUcodes.php
Old Dec 18, 2009 | 09:42 PM
dmeconitas's Avatar
Well if you look at my other thread about timing then you can get the full story. Here is the short story. Car was running, went to start it next morning didnt. I investigated and found no spark so replaced the ignition module in the dizzy. Still wouldnt start, got a hold of an air gun took pulley off adjusted and made sure everything was tdc. Cranked car over ran like a camp. Turn car off and on bunch of times to make sure and it still ran. Button everything up to take for test drive and car would not start and have cel now.
thanks big chor!zo. So does this mean I burnt another ignition module?
Old Dec 18, 2009 | 09:45 PM
it could be a bad ignition starter switch located inside the steering column...!!!
Old Dec 18, 2009 | 09:47 PM
dmeconitas's Avatar
So if I test the igintion module, check the key ignition. About half away ago some noobs tried to steal the rex when it was down and had a flat tire. All they made off with was a hat and left the hood open but I guess they didnt see the goodies under the hood.
vatozone wants 50 yucks for that. I will look up and see if I can test it to make sure.
Old Dec 19, 2009 | 08:27 AM
JDMefHATCH7's Avatar
yessuhhh
they do tend to always stop working for one reason or another
go to the junkyard and get it
djtsmith007
Oct 26, 2007 11:34 PM
M-EJ1
May 23, 2004 05:49 AM
dremmel
10
Apr 29, 2004 09:54 AM
quik1
Nov 4, 2003 04:29 PM
sackdz
10
Oct 6, 2003 08:11 PM
