Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
coil packs!!!!
Old Dec 18, 2009 | 07:42 PM
cleansi's Avatar
Default coil packs!!!!
does any one know how to test them or to tell if they are deffective
Old Dec 19, 2009 | 04:38 PM
Ross 2.0's Avatar
In a Junkyard near you.
Default Re: coil packs!!!!
With the car running unplug them one by one, if the engine starts missing you know that one is good. Coil packs work or don't, there is no in between. But since you have a 2000 if the car is running you can assume the coil is good. lol
Old Dec 19, 2009 | 07:44 PM
Micha's Avatar
FAILWGN
Why is this in the 8th gen forum?
And there are no coil packs on a 2000 si.
Old Dec 19, 2009 | 08:34 PM
i-VTEC_DOHC's Avatar
maybe its for a friend of his, or he has a car with coil packs that isnt added to his garage here on h-t.
Old Dec 27, 2009 | 12:37 PM
Nsane's Avatar
you need to find the resistance specs and measure them with a ohmmeter to see if they within specified range.
Old Dec 28, 2009 | 11:40 AM
LOrangeH22hatch's Avatar
Is it throwing any miss fire codes?
If so, clear the codes.
Then take the coil from the cylinder that the code indicates and move it to another cylinder.
Test drive the car and if the code follows the coil then the coil is the problem
Hope that this helps.
Helldawg
Nov 9, 2015 07:32 PM
spunky424
Dec 12, 2004 10:01 AM
love2xlr8integra
Aug 23, 2004 06:32 PM
