honda del sol sway bar bushings
was wondering if anyone knows the size of the front sway bar for a 1995 honda del sol si ..cause i am doing the bushings on the car and want to do the sway bar bushings..
actually the s, si has the 21mm
51300-SR3-013 SPRING, FR. STABILIZER (21MM) (NIPPON HATSUJO)
so OP, here's the d-bushing - http://www.energysuspension.com/sear...partNumSearch=
or OEM# 51306-SR3-010
and end links - http://www.energysuspension.com/sear...partNumSearch=
or you can get the indivdual pieces from honda
and end links (interchangeable between all trims) - http://www.energysuspension.com/sear...partNumSearch=
