My D16z6 just broke...get me a new engine! Going into Ej2 coupe
Buying: D16Z6 engine (1995+) or a B18B1 engine (5-speed MANUAL only)
D16Z6 specs:
- GOOD running condition
- No oil leaks
- No problems, must be in working order
- OBD1
B18B1 specs:
- same as above
- Need transmission mount
- Shift linkage
- B18B1 ecu
- OBD 1!!!!
Looking to pay straight cash for a running swap! Drop off preferred.
UPDATE to why I need a new engine:
D16z6 broken crank bolt
Thanks,
Jon
D16Z6 specs:
- No oil leaks
- OBD1
B18B1 specs:
- same as above
- Shift linkage
- B18B1 ecu
- OBD 1!!!!
Thanks,
Jon
@DADOHCturbo thanks for the link! Id love to buy a jdm motor but that wont pass smog from what I hear. Those prices are pretty cheap too!
Actually I get your question - no i didnt overtorque the bolt. it was running then suddenly engine started acting weird. pulled over and the crankshaft pulley was hanging off slanted off the crankshaft. Had to get towed back.
Looking to buy one by end of sunday - needs to be in good condition! No leaks, absolultely nothing wrong with it.
i would drill it,relieve some stress on it and you might be able to back it out-
or pull the crank out and have a machine shop remove the broken bolt.
is that thread lock? keep this to the top, let get him a motor asap, and sorry i haven't gotten back to u about your other z6, money got tight real fast
Thats cool man - the other Z6 i might have to pull the crank outta there and put into here but that would mean rebuilding this whole motor which is easily 500+ bucks.
I mean the bolt was torqued in and it broke offwhile driving (which no idea why)
micahr
Aug 9, 2017 06:10 PM
