fuel / pump e85 with around 460-500whp
Old Dec 18, 2009 | 01:34 AM
IceySC's Avatar
Default fuel / pump e85 with around 460-500whp
im still so new to the turbo game .im trying to finsh my setup i have a built gsr that im trying to put down around 460-500whp as of now i have a 255 fuel pump and i just picked up the Injector Dynamics 1000cc Fuel Injectors and im going to run the car on e85 for the sake its cheaper and its eazier to find were im at .but i was told the fuel pump will be to small. is this true? if so what can i do i really dont want to buy a $300. pump.please help.
Old Dec 19, 2009 | 12:10 AM
IceySC's Avatar
Default Re: fuel / pump e85 with around 460-500whp
please help ..
Old Dec 19, 2009 | 01:55 AM
99V-unit's Avatar
im on the same boat as you, i just asked the same question. How much did you get the id 1000cc for.
Old Dec 19, 2009 | 10:42 AM
IceySC's Avatar
$501. shipped
Old Dec 19, 2009 | 11:23 AM
MAperformance's Avatar
500whp is attainable with a single Ford GT in tank pump and the saturated 1000cc injectors from ID or Fuel Injector Clinic.
Old Dec 19, 2009 | 11:58 PM
IceySC's Avatar
what would the max be on the 255 running e85?
Old Dec 20, 2009 | 05:05 PM
IceySC's Avatar
bumb
Old Dec 20, 2009 | 05:29 PM
092eg6's Avatar
the pump would be fine but i think the 1000cc wont be enough
a guy here max out his 1000cc on e85 with only 350hp
Old Dec 20, 2009 | 05:40 PM
gringotegra's Avatar
so then how did i do 444whp with a single 255 and 880cc injectors?
the 1000's are enough to do 500whp but i thinnk you will be maxxed out with the 255 or damn near maxxed out..ive seen 460whp on a single 255 with 1000's on E98, and the injectors were about out though (They wernt ID's tho)
Old Dec 20, 2009 | 05:51 PM
DADOHCturbo's Avatar
wish E85 was at more pumps in Socal
Old Dec 20, 2009 | 06:01 PM
092eg6's Avatar
wel not sure, he just told me it was maxed out!
Old Dec 21, 2009 | 12:49 AM
IceySC's Avatar
ford gt pump ? do you have a link i would think the Injector Dynamics injectors would be maxed out at 500whp on e85 . there has to be more people on here thats done it.
Old Dec 21, 2009 | 07:54 AM
Part number on the GT pump assembly is 4G7Z-9A407-CA
As for a single walbro and the saturated 1000cc injectors from ID or Fuel Injector Clinic, i've seen up to 513whp, but also as low as 460whp. Every set-up is different.
Old Dec 21, 2009 | 08:01 AM
99JDMHATCH's Avatar
Made 343 on 550s.
Honestly dont post with he said she said BS.
Old Dec 21, 2009 | 09:35 AM
scmil95eg's Avatar
Here's the thing: Ideally, you want the pump to be capable of about 15% more volume than what the injectors can flow at the pressure you're going to run them at.
At 45 psi, your ID1000's will flow 95 lb/hr each x 4 = 380 lb/hr
At 50 psi, your Walbro 255 will flow about 390 lb/hr
That's only a 3% difference - and that's if you get a good Walbro that flows what it should.
But now we have to compensate for boost.... since I don't know what you're running, I'll figure a hypothetical 20psi:
The delta across the injectors (ideally) shouldn't change, so they are still going to be capable of flowing 380 lb/hr.
But now the pump has an additional 20 psi to push against and at 70 psi, it's flow drops to 335 lb/hr. That means at about 85% duty - you're done! Out of fuel.
Just keep this in mind so when you're tuning and you start to reach 75% ~ 80% duty cycles, someone starts watching a fuel pressure gauge because you'll be very close to a catastrophe.
Old Dec 21, 2009 | 09:46 AM
scmil95eg's Avatar
390 / .7 = 557 hp (crankshaft)
335 / .7 = 478 hp (crankshaft)
Old Dec 21, 2009 | 10:40 PM
99V-unit's Avatar
hey have you had any experience with holley fuel pumps, i saw on their website that they got a holley feul pump 255 for $164 and it says it supports up to 650hp. any advice?
here is the link, now whats the difference from the walbro 255 fuel pump from the holley 255.
here is the link
http://www.holley.com/12-906.asp
Old Dec 21, 2009 | 11:13 PM
IceySC's Avatar
i just looked at one of the cars on tony1 web site he made 435whp with the 255 pump and id 1000 injectors . but im still feeling it maybe maxing the pump out. is the 255 the biggest pump walbro makes and what the biggest in tank i can run.
Old Dec 21, 2009 | 11:53 PM
99V-unit's Avatar
I might get the holley fuel pump, they say it will support up to 750hp and its an intank fuel pump easy to install and its only 184 free shipping.
Old Dec 22, 2009 | 06:07 AM
scmil95eg's Avatar
That link shows a 255 lph in-tank pump that looks identical to a Walbro. 255 lph is 255 lph, regardless if it's Holley or Walbro.....
This is where I strongly disagree with the marketing that goes on with 'fuel stuff'.
They could claim that same pumps supports 1000 HP since it flows 500 lb/hr. Too bad it flows 500 lb/hr at 0 psi and it would be tough to run any fuel injection system at 0 psi..... There are zero standards or specifications when it comes to these HP claims and because of this, you really have to understand what you need, and why you need it.
1. They don't specify the system pressure for that HP rating
2. They don't specify a fuel for that HP rating
Those are two fairly important parameters when it comes to setting up a system.
It you ran it to a carburetor at 5 psi on gas, it could very well support 1000+ HP, but if that's not what you are going to do with it - what good does it do you? There are some companies that really take advantage of this, I've helped a lot of people who have been misled and screwed by these exact same 'ratings'.
Cliffs: looks like a walbro 255 with install. kit to me.
Old Dec 22, 2009 | 06:23 AM
Ive got that same holley kit...its just a 255 and i was damn near out of fuel with 880's and E85 @440whp...
Old Dec 22, 2009 | 05:37 PM
IceySC's Avatar
thank you all for all the info . what is the best place to pick up a 044 price wise ? and doe anyone do any package deals on the pumps ?
Old Dec 24, 2009 | 10:49 PM
N1 Andy's Avatar
R.I.P. Andy
dammit! I wish there was a e85 station closer to me!
I would have loved to tune on that
Old Dec 25, 2009 | 12:18 AM
IceySC's Avatar
looking for package deal on the pump or the best place to buy it.
Old Dec 25, 2009 | 11:42 AM
T9U4ReBgO's Avatar
I just tuned on e85...Made around 350whp with a walbro 255 and precision 1000's. My duty cycle was 73% with 60 base fuel pressure.
I'm also local to you...
