changing timing belt in gsr. video or walkthrough?
search, there is a great walkthrough. i can tell you the single most important part is installing the belt in the correct sequence and doing the three tooth rotation to apply tension before you lock down the tensioner. also rotate the engine counterclockwise at least 2 full rotations and recheck your marks to confirm you have it right.
There are several great walkthroughs and all you have to do is google search for them. Also visit the articles section on team-integra.net. I don't know which subcategory it's in, but there's an illustrated article there on timing belt installation.
here's a few links. same process for pretty much all hondas
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/%5Bfaq%5D-complete-diy-how-timing-belt-water-pump-change-d16z6-lots-pics-649277/
https://honda-tech.com/forums/honda-accord-1990-2002-2/how-replace-timing-belt-timing-balancer-belt-water-pump-f22b1-1908944/
http://www.c-speedracing.com/howto/timingbelt/tbelt.php
GQ 05YellowEVO8
Apr 5, 2003 06:03 AM
