manifold runner length and spoon time
Old Dec 17, 2009 | 05:48 PM
silverwrench's Avatar
Default manifold runner length and spoon time
i'm wanting to mount my turbo under the intake manifold for to have it kinda hidden for a sleeper look. i have an ebay t3t4 50 trim to use but not sure if it will spool decent all the way back there. i was thinking i would need something small like a t25 or 14b or something like that. but then i look at ramhorn and topmounts and so on and those have fairly long runners and still use decent sized turbos, but those are also used for higher hp at high rpm. just wondering what i should use for a 250whp daily driver.
Old Dec 17, 2009 | 06:01 PM
TheShodan's Avatar
Moderator
Default Re: manifold runner length and spoon time
log manifolds.. done.
Old Dec 17, 2009 | 06:17 PM
that didn't answer my question but if this idea doesn't work that is probably what i will use
Old Dec 17, 2009 | 06:28 PM
boostedEF91's Avatar
he means a use a log manifold.. a log manifold sits down below the head. so you cant see it as much. as for you saying you want to put it back under the intake. good luck with that. dont think you can do it. just go simple and stop trying to hid a boosted car and show your stuff.
Old Dec 17, 2009 | 06:33 PM
i think it will work just not sure what turbo to use to get decent spool
Old Dec 17, 2009 | 11:07 PM
ndondahows's Avatar
Just remember, the more piping pre, and post turbo you have the longer its going to take to spool up..Sounds like too much work and not enough gain or any gain in my opinion
Old Dec 17, 2009 | 11:27 PM
grndcont's Avatar
waste of time and $. if you dont want to see a turbo under the hood but still want the power...use n20.
Old Dec 18, 2009 | 05:31 AM
yeah i get that but what about ramhorns and top mounts? both of those are used to make big gains right? i want to use the stock d16z6 manifold and down pipe and bend up were it meets the firewall. i figure i can keep the exhaust speed up by having it bottle neck after it starts to cool.
Old Dec 18, 2009 | 05:36 AM
Turbo-charged's Avatar
this header is def. long enough to place the turbo under the intake manifold. 35r, makes full boost at 5k (just as good if not better than most 35r's) and made 660 to the tire at 25lbs of boost at 50% duty cycle on the boost controller.
Old Dec 18, 2009 | 05:43 AM
that is awesome, and that is a lot of pipe, i'm gonna try it. i still think i'm gonna look for a smaller turbo though. thanks for the pics and info dude
Old Dec 18, 2009 | 06:35 AM
shifty35's Avatar
I don't think there would be any problem mounting the turbo in the rear of the engine. Logistically, there may be some packaging problems, ie, making it actually fit without hitting stuff, and getting charge / oil lines in / out.
Old Dec 18, 2009 | 07:55 AM
Glove's Avatar
thats the sweetest setup ive ever seen
Old Dec 18, 2009 | 03:41 PM
yeah i hear ya on that but nothing a little cutting can't take care of lol!
Old Dec 18, 2009 | 04:14 PM
K7-1Ktrevor's Avatar
Loved
Community Favorite
for a rookie. just keep it simple man. if you want to hide the turbo build a heat sheild off the log that will cover it, you could fab it to make it look almost like a stock exhaust manifold heat sheild.
Old Dec 18, 2009 | 04:34 PM
91jdmhatchback's Avatar
here is a setup i made to try and hide the turbo as best i could, most didn't know it was turboed.
welded nuts to the manifold, so i could bolt on a hf heat shield.
installed in the car
without the shield
rastaintegra
Mar 23, 2012 04:13 PM
koulaid
Oct 21, 2008 08:17 AM
hondaboii
Welding / Fabrication
26
Feb 4, 2006 03:53 PM
eg2phosizzle
11
Jan 24, 2006 09:37 AM
eg1point8
Oct 17, 2005 11:50 AM
