GSR Tranny vs LS tranny!
Hey guys i would like to know on GSR tranny doing 75-80mph in 5th gear what RPM would it be? and same speed on LS tranny what RPM? I know that LS gears are longer but still want to see how much difference?
You should be able to get a good idea using a gear calculator.
http://www.teammfactory.com/gearcalculator.php
Ya I think the preferred setup is having a gsr trans for the LSD and then an LS 4th and 5th so you can get longer gears and ride out to a higher speed before you shift. Unfortunately as far as I know there is no one that makes an LSD for the ls/gs transmission. If there is, someone please let me know so I don't buy a gsr trans and change out my LS 4th/5th gear to that trans for no reason lol.
Actually, the MFactory calculator is stating that a GSR, with 4.4FD, and 195/55/15 tires is going 83 mph, at 4000 RPM's.
What?
I've had a LS and B16 in my teg with 195/60-14 tires and at 80mph the LS was at 3500 and the B16 was at 4600, so I know the GSR has to be less than 4600.
What would you rather have, a turbo that takes 1 second to reach peak boost, or one that takes 3 seconds to reach peak boost, same applies with transmissions.
LOL! Longer "taller gears", or "lower gear ratios" can be beneficial when traction is an issue, but to generically state that an "LS tranny is better for boost," is absurd.
Lower gear ratio should not be an issue. Remember, LS and B16 have the same 1st gears, so traction should not be used as an argument for one that says LS tranny is better for boost. If you don't have the right suspension, tire combo, traction will be an issue no matter what tranny you're using. And if you don't have traction by at least 2nd gear, then you don't know how to drive.
A motor puts down as much power as you allow it to, as the driver, you are in complete control. I would much rather feather the clutch and launch with a bit less throttle and have traction immediately, than launch at 7k rpm and burnout the entire 1st gear.
Ok so i don't understand! Why does my 92 LS Transmission on a 94 B18B1 motor in a 90 integra obd0 with stock ecu on factory 195/60r14 say 80MPH at 4k?!?!?!?
Also this is my 4th trans and they all do the same as this one.
Aren't those tires significantly smaller than the stock tires? Aren't stock tires 185/55/15?
I cruise at 4k in my GSR at 80 mph. No LSD unless its some rare JDM GSR. What differences are there between LS and GSR tranny other than gear ratio? My synchros are gone, I can't afford a GSR tranny
