B20 vtec and D16 swap obd1 compatability. ? 's
Old Dec 17, 2009 | 12:18 PM
Xemu's Avatar
Default B20 vtec and D16 swap obd1 compatability. ? 's
Can someone provide me with a list/link of parts I can pull off my A6 block Vzw head mini me swap
To use on my B20b vtec swap. Both are obd1 any help would be greatly appreciated. Thanks
This is going into a 1988 Crx Si. Thanks
Old Dec 17, 2009 | 10:04 PM
Xemu's Avatar
Default Re: B20 vtec and D16 swap obd1 compatability. ? 's
Come on 30 views and not one of you can help a brotha out. Please........
Old Dec 17, 2009 | 10:11 PM
BiG ChOr!Zo's Avatar
im no rocket scientist but i believe that d-series and b-series engine parts are not interchangable...it could also be that your question doesn't make any sense to begin with
Old Dec 17, 2009 | 10:12 PM
crx_si-r's Avatar
B-series parts are nor interchangeable with D-Series.
the only parts you can re-use from the mini-me swap is the harness and ecu, bu the motor will not run right. Come on now, its common sense. stop trying to cut corners and get what is needed to do the swap
Old Dec 18, 2009 | 08:09 AM
Xemu's Avatar
You know what I love it when people talk like they know what they are talking about but really don't??? I pulled my D16Z6 Vtec Solenoid off and it bolted right up to my B16A2 head......hmmmmmmmm wonder what else. Good thing I'm cutting corners cause I just saved myself some money on a solenoid that I can use somewhere else. Thanks for the useful info.
Old Dec 18, 2009 | 08:10 AM
Xemu's Avatar
Old Dec 18, 2009 | 08:44 AM
crx_si-r's Avatar
Ahhhhhhh newbies, yes it bolts up. What's your point? Look at the pressure switch placement, look different? Don't try and school me because your too cheap to do thngs the right way. Just cause something bolts up doesn't mean it will work right. I know it bolts up whether it works right I don't know because I do things the way theyare supposed to be done. I see more posts about issues with this build coming soon
Old Dec 18, 2009 | 09:01 AM
mayfly's Avatar
were u born stupid or did special ed class not teach u anything? ur tryin to talk **** to two guys on here tht have always had good tech, nd know there **** nd have build threads, so my question is where the F is ur credibility? they earned there's
Old Dec 18, 2009 | 09:13 AM
nowthatsG's Avatar
if your going to do the swap do it right! there are so many parts out there that you can find all the parts you need for cheap, my buddy the other day sold his b16a solenoid for like 10 or 15 bucks, so come on..... plus dont post on here with questions that your going to get butt hurt on when people give you there opinion....which the opinion everyone has is dont cut corners bc its goin to suck in the long run,....trust me when have either tried the shortcuts at sometime in our life or know someone who has, and trust me when doing a swap its not worth it.......so to sum it all up DO IT RIGHT
Old Dec 18, 2009 | 09:15 AM
crx_si-r's Avatar
If, you really want you can gut your z6 distributor and swap the Internals into a junk obd1 or obd2 distributor. Your sensors are the same. Aside from that, that's it
bar'dh22's Avatar
there are plenty of things that will work from your d series to the b series just about every sensor will work fuel injectors will work fly wheel and pressure plate bolts , the d series vtec Solenoid does bolt to the b series head i will give you that but before making a jackass statement you should look up the flow and pressure rate and you would see that they are different if you use the d series solenoid on your b20vtec your cams are gonna burn
Old Dec 18, 2009 | 09:19 AM
crx_si-r's Avatar
Good lookin out I forgot about the injectors
Old Dec 18, 2009 | 09:28 AM
Xemu's Avatar
First off chucklehead ease up on the Red Bull and relax dude. I believe I read in his post and I quote:"B-series parts are nor interchangeable with D-Series."
Not trying to be a dick but I also want to get "correct" info. First nothing can be used and now some things can be used. How I look at it is if your not going to give me info about the info I inquired about butt the hell out and quit stirring the pot with your worthless info. I never said they didn't know anything but it's apparent you don't- otherwise rather than wasting the bandwith with pointless drabble how about answering the question??? So I guess "now" there are parts that can be used........hmmmmmmmmmm.
Old Dec 18, 2009 | 09:35 AM
crx_si-r's Avatar
I stand by what I sad do it right. I hear people say the combo doesn't last but I'm going strong on 4yrs with my lsv because I did it right. You want your swap to last, then do it right.
mayfly's Avatar
omg omg omg i never knew that u could use those little parts, oh wait i did learn that, in tech school. the main bigger parts is wut ur lookin for to change correct? nd the hassle u r gonna go through to change em out is not worth it, besides ur b20 should have the sensors nd parts in them, so u have no need to really change em out,
Old Dec 18, 2009 | 09:57 AM
crx_si-r's Avatar
That's why I didn't originally mention them, those are parts I Would swap with new ones to begin with.
Old Dec 18, 2009 | 11:06 AM
Xemu's Avatar
They were originally bought new on the d series swap and seeing how I'm starting with a bare block
(Crank,girdle,rods,pistons) nothing on the outside of the block. If someone had stated that you can actually
Use d series stuff on b series It would've been appreciated. But apparently that's commen knowledge.
Old Dec 18, 2009 | 11:09 AM
Xemu's Avatar
So then actually the solenoid is usable you just need to swap the pressure
Switch from a b series but you can use the d series solenoid?
Old Dec 18, 2009 | 01:05 PM
bar'dh22's Avatar
not just the pressure switch the actual inside of the b series vtec solenoid has larger oil flow ports
Old Dec 18, 2009 | 01:20 PM
.Manny.'s Avatar
Touching My Member
Old Dec 18, 2009 | 04:24 PM
Xemu's Avatar
Originally Posted by .Manny.
This forum is cracking me up. Always heard it was a place to get info/help but I was lucky enough
today to find out that there's just certain stuff you should know and if you don't than don't ask on this forum
cause everybodys on this forum would much rather make an uninformative comment than actually help us stupid people out. Bwaaaaaahaahaa Too freaking funny.
Old Dec 18, 2009 | 04:25 PM
.Manny.'s Avatar
Touching My Member
exactly. welcome
Old Dec 18, 2009 | 08:10 PM
Xemu's Avatar
exactly. welcome
Maybe this will clear things up. Read it: Then come back with a uneducated icon??? Bwaaahaaaahaaa. Oh snap !!!!
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/d16z6-upgrade-vtec-solenoid-2207340/
Old Dec 18, 2009 | 08:14 PM
Xemu's Avatar
If the vtec solenoid bolts on it'll work. Its just a switch that's filled with oil. If the solenoid and its filter gasket fit nicely it will do the trick. Vtec isn't going to be affected at all or improved etc. Some vtec solenoids don't bolt up ie d16y8 solenoids don't bolt up to b series motors so maybe that's where all this info has gotten incorrect. All obd2 jdm b series motors do not have a pressure switch since the switch is electronic.
Old Dec 18, 2009 | 08:56 PM
crx_si-r's Avatar
do you have an obd2 ecu to run your B20Vtec? if not then shut up and listen. obd1 ecu's require an oil pressure switch. DING DING DING, i think school is in. Stop wasting our time and do what ever you want with your car. its up to you how you want to run it.
