Fair price on GSR engine???
Old Dec 17, 2009 | 12:06 PM
civic_nick2's Avatar
Default Fair price on GSR engine???
What would be a fair price for a well maintained GSR engine with 225k? My engine is leaking a lot of oil and want to replace it.
I'm looking to buy and rebuild to OEM Spec.
He's asking for $800
It is from a 95 GSR B18C1
Daily driver and a few autocross.
Not sure about the leak down and compression.
Old Dec 17, 2009 | 12:52 PM
racebum's Avatar
Default Re: Fair price on GSR engine???
quick comment on buy and rebuild to oem
you'll spend more than a $1500 jdm gsr and probably more than a 2300 jdm itr
if that engine is complete it's a not a bad deal but i think you would be money ahead going with a jdm swap
Old Dec 17, 2009 | 01:02 PM
SergEK's Avatar
Cant you just do a hone and new overbore OEM pistons for your motor? Is it the valves leaking or blowby?
GSR engines alone are 1800 retail...used...who knows condition wise
Do an H2B swap instead F20B FTW!
Old Dec 17, 2009 | 01:31 PM
racebum's Avatar
mmmm...you can do a little better, something like
http://cgi.ebay.com/ebaymotors/JDM-I...ht_2688wt_1165
as far as the rebuild goes many times you can just do a hone and reuse your old pistons with new rings; however, the top end often needs guides, new exhaust valves, a good deal of gaskets and seals, decking the head and block + the labor and time. if the OP spent 800 on this one and did a simple rebuild it would run about the same as the JDM motor linked above BUT the jdm engine is lower mile everywhere. bearings, casting, all of it.
Old Dec 17, 2009 | 10:42 PM
rhymeshark916's Avatar
You are right. I had to replaced exhaust valves and guides when I bought my b18c1 off the street. It was almost $200 that I didn't plan on with the "oem' rebuilt. I would of went with a jdm swap but it isn't legal here in CA and usdm b18c5 is rare and expensive. $1650 isn't bad for a gsr but they added shipping cost already. $800, it's worth it if you plan on building it to a type r spec and get some power or if you just want a replacement then get a low mileage gsr.
Old Dec 17, 2009 | 11:09 PM
tegradriver's Avatar
I recently crashed my 99 LS and I'm looking to fix it, does anyone know the street value of a LS motor w 200K? Id much rather do the JDM engine than put back in my other one after I fix the frame. HAs anyone done anything like this before?
Whats a common install price for the JDM GSR ?
Old Dec 18, 2009 | 12:13 AM
racebum's Avatar
it varies, i normally do gsr or itr swaps into a 94-01 integra for $450 plus parts if you run it jdm or $600 if you want the usdm obd2a conversion. most shops are around $700-1200, it really varies.
Old Dec 18, 2009 | 12:33 AM
Hmm.. I like your style. How much Should getiing all of my engine mounts fixed cost me? I have alot of repairs that need to be done , and not as much disposable money for the project. I might not swop depending on how much It costs. and where I can get the GSR motor for. I have a 99 LS
Any realistic estimates of some front end frame work would be awesome as well.
Old Dec 18, 2009 | 12:38 AM
racebum's Avatar
you might be money ahead selling and buying a new car. engine mounts aren't expensive except for that rear one....it's a bitch. the side ones that create axle hop when they go are easy to change. probably $25 each in labor plus parts. the rear one i would have to look at again to get an idea but it's at least $75 in labor..it's a bitch
Old Dec 18, 2009 | 09:25 AM
Way over priced....I guess
Old Dec 18, 2009 | 10:45 AM
racebum's Avatar
do it yourself then
Old Dec 18, 2009 | 11:54 AM
all-mtr-teg's Avatar
$450 for a complete motor swap is a good price. Most shops charge $300-400 just for a timing belt, water pump job.
Old Dec 18, 2009 | 02:23 PM
How much money ahead do you think I can get from my LS? I still have a few months of payments till I get the title.
Old Dec 18, 2009 | 03:21 PM
teg_95's Avatar
X2
Old Dec 18, 2009 | 03:55 PM
THis is good news , how much do they cost? for a set of engine mounts?
Old Dec 18, 2009 | 04:14 PM
racebum's Avatar
price them on ebay and www.acuraoemparts.com, the ones from acura are higher quality and will live longer. if you drive aggressive the $40 energy suspension mount reinforcement kit will prevent them tearing but it only fits oem mounts. many aftermarket mounts are close to oem but molded ever so slightly different.
Old Dec 20, 2009 | 09:59 AM
Hey thats great information! Its so hard to find mechanics and tuners who actualy know what they are talking about! I know that 3 0f 5 mechanics just try and take my money, and rip me off.
Thanks guys for your help, this is the biggest car project I've ever had.
Old Dec 20, 2009 | 11:52 AM
racebum's Avatar
welcome, but keep in mind some of the prices i put out there were personal labor rates, not shop labor. if someone has overhead to pay for the price has to be higher
Old Dec 20, 2009 | 12:11 PM
Understood, thats why I'm on here and not at the euro and import shop I normaly go to. Because I know the rates. I just can't afford it with how much work I have to get done. That and I have to tow my car to where I get the work done at.
I checked on acura and the OEM motor mounts are like 55-75$ each. Is that reasonable? Going to check junk yards today to see the inventory of 3rd GEN integra's. How realistic is it to think I could find new ones? and is it unrealistic to think I can take them off @ the junk yard?
99importnizl
34
Apr 3, 2003 12:24 AM
1hotintegra
Jun 6, 2002 05:32 AM
