Rease's Sedan Build
Finally decided to bring my lsv build over to h-t. i have it already started on dseries but since its a b ill bring it here. prolly get more responses here.
My plan
Engine:
ls Block 81.5 bore
gsr head reconditioned with bc springs and retainers(undecided on cams for now gsr cams)
rs machine pr3 pistons 11.1 c/r
kg lsv dowel pins and oil line
mfactory sandwich
vtec wp/op/tbelt
Aebs intake mani
innovative mounts
gsr exhaust manifold mated to stock exhaust
Trans:
92-93 gsr ys1 cable clutch(unknown condition og said 3gear grind)
stock clutch and flywheel
innovative shift linkage
ebay shifter (bought off member on d-series)
Suspension
nothing yet still planning)
Stock springs
stock shocks
stock camber
Shoes:
hubcaps came on the car
well enought of parts here are some pics from when i bought it in july - it was automatic and parts were taken from 2car to make one and he sold it as is. didnt say anything about a rod knock. was over filled with oil all the way to the top. rode fine was able to make it home before knocking started.
My plan
Engine:
ls Block 81.5 bore
mfactory sandwich
vtec wp/op/tbelt
Aebs intake mani
innovative mounts
Trans:
Suspension
nothing yet still planning) Stock springs
stock shocks
stock camber
Shoes:
now on to the motor build. here are some pics of when i was tearing it down and what not
UNUSED LS RODS (SAVING FOR BOOST BLOCK)
rebuilt and packaged
finally got some motivation and put block and trans into car
then got to putting head on the block and bought aebs intake mani and vented the block with the ports from prelude
thanks im trying to get this on the road as quick as i can. work from 11am-730pm and its cold out when i get home/all day hate pa weather. what plug is on this gsr tb.
recieved my chip kit yesterday got 3 bags of parts from xenocron. going to try to tackle chipping and adding vtec to my pr4 ecu. still need to convert the harness and make my jumper harness. gotta drill the 2 rear holes to mount the shift linkage and drill the hole for the clutch cable. is going to be a b*itch to do since i have no idea where to drill the whole. thought about taking the dash off and drill from the inside to the bay. what do you guys recommend.
for the harness i just follow the pin out for both ecu's correct.
finally got my obd0-1 ecu diagram made so i can start soldering my jumper harness. also got my drive axle 94+ since i have the 94+ dc half shaft.
here is my diagram i made on excel. open with excel if u can. decided im going to paint my sedan Montreal Blue Metallic Clearcoat........B-35 1988 which will look like this but just the sedan. the blue on the trunk is the og of the car.
i want to get ride of power steering do i just need to buy manual rack or do i need a rear cross member also? if i was to keep power steering with my lsv swap what pump and and can i reuse the civic hoses?
haha that teg is sexy with da paint... im suppose to be painting it soon as the weather breaks. got sum underbody rust i need to get ride of any suggestions?
after doing some reading on cams and springs. alot of people say not to mix n match cams and springs. i have bc springs and retainers. i am not buying cams just yet but if i was to would i have to get cams
how will these cams perform on my setup and says i will be able to rev to 9k.
63402A-2 Stage 2
Stock idle lobes (sec/pri) with #63402 VTEC (mid) lobes.Recommend #84163 spring unless stock rev limit.RPM Range: Idle to 9250+ 18+ hp over B18C
Advertised Duration Int- 311 mid Exh-308 mid
Duration @ .050" Int- 255 mid Exh-248 mid
Gross Lift w/1.55 Int- 466 mid Exh-466 mid
63402A-2 Stage 2
ttt for answers
well this weekend i got around to drilling holes for the shift linkage and put in shifter from ed wagon haha here is the pics looks like one of those performance shifters.
back to update this thread. havent done much work on this car.
well i plan on doing a da front knuckle swap to get bigger brakes for the lsv swap. im in the process of taking the motor back out the car so i can put the crank pully on and time the motor and attach the engine harness once i recieve it. i was going to tuck the harness but decided to just go with monotech conversion harness for 300. he does nice work.
before i started taking the motor out i was messing with the shifter and feels so slopy. not sure what the cause or case would be to fix that but it was an auto and i swapped to manual. innovative linkage.
