NEED HELP! no idea whats going on with my car
ok, so last night i wired up my electronic VSS directly to the ECU, used pin A2 as a ground and A13 as a 12v power supply, then ran the VSS wire to B16 (as directed by Rywire). the car ran perfect all last night and most of today. was hitting vtec and everything. not throwing any codes. i go to autozone to get a new cap, rotor, and plugs. come out and my car wont start. the brake warning light is on, and the oil warning light, battery light, and check engine light are VERY DIM when the key is in the ON position. the LED light on top of the ECU stays on instead of flashing. BUT when i hold the trans in gear (only 2nd or 4th) all the lights turn on and the light on the ECU turns off like it should (but i really have to pull on the shifter hard for that to happen). i checked the main relay, its fine, checked the ignition switch, thats fine. i know its not the ECU. i checked my grounds, theyre all tight (unless theres one i dont know about) meaning, thermostat housing, negative for battery, valve cover.
what is going on?
what is going on?
ok, now i have another problem. i took the ecu out to see if the car would at least turn over. with the ecu unplugged, the ignition came on as it should. but as soon as i turned the key to start it, the started engaged but then i had no power at all. as if the battery was unplugged. then i let it sit for a bit, came back, plugged the ecu back in, and turned the key and everything came on as it should. then tried to start it but then everything shut off again. then i tried to push start the car and for some reason my trans is locked up. it was like hitting a brick wall when i released the clutch.
rayzian
13
Feb 22, 2018 04:54 PM
rudyndrew
Jan 5, 2011 05:32 PM
jondancer
Apr 24, 2004 09:39 AM
