Forced Induction Everything Forced Induction (Ex: Turbo Kits, Intercoolers, Blowoff valves, IC Piping, Turbo Manifolds)
MAPerformance Complete B-series Turbo Kit 92-00 Civic/Integra $2999 Shipped!
Old Dec 16, 2009 | 02:29 PM
MAperformance's Avatar
Default MAPerformance Complete B-series Turbo Kit 92-00 Civic/Integra $2999 Shipped!
This is a complete bolt-on kit for the Honda B-Series motor in a 92-00 Honda Civic or 94-01 Acura Integra w/ half core radiator.
The kit includes:
Equal Length Turbo Manifold made of 321 Stainless Steel
3" Stainless Steel Downpipe w/ V-Band Outlet & Extension Pipe
1.5" Stainless Steel Dump tube
2000 Degree Black Ceramic Coating
Tial 38mm MVS V-Band Wastegate*
Precision Turbocharger*
Front Mount Intercooler*
Intercooler Piping 100% Tig Welded
Reinforced Silicone Couplers
Clampco Stainless Steel T-Bolt Clamps
Tial 50mm blow off valve
Stealthmode Stainless Steel oil feed line kit
ATP Oil Restrictor
MAPerformance Oil Return Line kit w/ oil pan weld fitting
12inch "Slimline" Radiator fan w/ Install kit
Necessary Gaskets
Current Stages Available:
Stage 1 250-400hp Kit $2999 Shipped
Extruded tube 29x6x2.5" Intercooler
PTE SC50 50 Trim Turbocharger
7psi Wastegate Spring
Stage 2 300-500hp Kit $3499 Shipped
Extruded tube 29X8X2.75" Intercooler
PTE 5857 Billet Turbocharger
10psi Wastegate Spring
Stage 3 400-650hp Kit $3749 Shipped
29X11X3" Intercooler
PTE 6262 Billet Turbocharger
14.5psi wastegate spring
Estimated installation time: 4-6 hours depending upon mechanical ability
Old Dec 17, 2009 | 09:38 AM
kulo's Avatar
Default Re: MAPerformance Complete B-series Turbo Kit 92-00 Civic/Integra $2999 Shipped!
any pics with ic fitted on ek?
Old Dec 19, 2009 | 09:06 AM
BoostedEgHatchFl's Avatar
I like how you have the bends in the ic piping when it comes out of the intercooler. Helps everything fit behind the front bumper. Do yall offer this in a ac compatiable kit?
Old Dec 19, 2009 | 09:25 AM
That it does!
Unfortunately i don't have an a/c compatible one jigged up yet. But you're looking at $500 Additional for a/c compatible.
Old Dec 19, 2009 | 08:39 PM
500 really? Most companys its only like 100 bucks more.
Old Dec 21, 2009 | 08:29 AM
Yes, unfortunately we're not jigged up for a/c compatible ram horns, the downipes, or dumptube. They are all different and will be 100% "custom".
The biggest difference between "most companies" and us, is that our kit won't take 3+ months get to you.
Old Dec 22, 2009 | 07:51 PM
dopeem1's Avatar
Anything d series? if so how much for a basic kit with a log manifold?
Old Dec 23, 2009 | 09:37 AM
Log manifold kit would be $400 cheaper for D-Series
Old Dec 29, 2009 | 09:02 AM
kulo's Avatar
any pics of these fitted/installed
Old Jan 1, 2010 | 06:17 PM
I'll try and get some posted up asap!
Old Jan 6, 2010 | 12:19 PM
Teamdiesel's Avatar
any installed pics on a 98+ civic?
Old Jan 6, 2010 | 12:39 PM
Unfortunately this is only one i have installed in an ek. It's also fitted with the 2 bolt 38mm flange.
Old Jan 11, 2010 | 09:33 AM
thelate1's Avatar
Any pics installed on an EG hatch? I'm curious on bumper fitment as well. What is your warranty policy on the manifold? Would you sell the intercooler piping kit separate? If so PM me a shipped price to 17603.
Thanks!
Old Jan 11, 2010 | 04:16 PM
1 year warranty on the manifold. No questions asked!
Old Jan 16, 2010 | 03:47 PM
bsmith100's Avatar
I noticed you had an asterisk * next to the turbo and the intercooler. Did that mean anything? Would it be possible to get the kit with a Garrett turbo instead?
I was also wondering if you had a cast straight-type manifold for a b series. I also need something that lets me keep my air conditioning.
Old Jan 18, 2010 | 08:24 AM
That asterisk is because the different "stages" have different options for those.
Yeah i can get it with straight garrett if you want, prices will change depending on what you want.
I don't currently have a cast manifold...
Old Feb 4, 2010 | 11:40 AM
deus_cy's Avatar
what you mean by all neccesary gaskets included? and whats the pipe sizes on the intercooler and piping? thanks
Old Feb 4, 2010 | 04:41 PM
Cylinder-turbo manifold, and turbine inlet gaskets.
2"-2.5" piping.
Old Feb 8, 2010 | 01:32 PM
BigSorn's Avatar
Looks like a solid kit.
Old Feb 9, 2010 | 02:05 PM
jdmnerdz's Avatar
wow looks clean
Old Feb 11, 2010 | 12:23 PM
civicexslammed's Avatar
bummmmpppppppppp
and damn some good pricing to from you guys
Old Mar 7, 2010 | 06:50 AM
jasonacura91's Avatar
could you pm me price on a log style manifold kit for b ser so i could keep my a/c thanks, thats if it is available..
Old Mar 20, 2010 | 05:58 PM
irishone's Avatar
Bump for the crew at MAP. I've done a ton of business with them for my Evo build. They're all great guys.
Old Apr 21, 2010 | 11:43 AM
project-boosteD's Avatar
i would like to get the stage one to replace the kit i have already, and right now i'm running 15psi on low and 20psi on high... will i beable to run on that on the stage 1? or would i need the stage 2?
