5th gen: Rear LCA Bushing
Old Dec 16, 2009 | 08:37 AM
E-Money's Avatar
Default 5th gen: Rear LCA Bushing
I PMed a few road racing members, did a search and now I needed to post a thread. On my base 5th gen Prelude, the bushing for the LCA to the subframe is completely trashed. The car has 209,XXX miles. Honda only sells the LCA as a complete set with bushings for the trailing arm, strut and subframe bushing. I dug a little deeper and noticed the 4th gen preludes (all models) sell the subframe bushing separately. They use the same bushings (identical part numbers) for the trailing arm and strut. But, the control arms are different part numbers for different generations. I believe it has something do with ABS or wheel sensors. Any if all input is appreciated about a easier way of doing this without replacing the whole control arm. And also to top this off, if any of you prelude owners have a bad knock in the rear. Look into this bushing.
Old Dec 16, 2009 | 09:37 AM
vinuneuro's Avatar
Default Re: 5th gen: Rear LCA Bushing
One more option is the Hardrace rubber bushing. It's a higher durometer rubber than what oem uses. They also have a trailing bushing. Specialprojectsms is the north american distributor, ht user Kiwi.
ross2004
Aug 22, 2018 11:06 AM
vinuneuro
Jun 24, 2014 06:01 PM
ekim952522000
May 23, 2009 01:21 AM
TraKtioN
Dec 28, 2007 02:43 AM
577HondaPrelude
Mar 4, 2005 12:02 PM
