crx problem
ive got a 90 crxsi and the car wont start.... i check the red light and i get code
20 Electronic load detector - possible open or grounded circuit in ECU wiring.
has anyone else happen to had this problem before...... ive been checking everything and i just cant seem to find the problem.... if anyone has any ideas then pls help me out thanks
ELD basically regulates your charging system.
I don't think it would prevent your car from starting.
If this part has been faulty for a long time then your battery might be damaged.
ELD is located in the fusebox in the engine bay.
Check your connections and clean up all your grounds.
If the code won't go away then try swapping the fusebox for another one.
