ef sohc zc popped hose question
i did search, and unfortunately i dont have pics but i need to know the name of the hose that connects from the firewall to the dizzy side of the head.
the hose is just to the right of the thermo housing and just to the left of the dizzy.
EDIT: is this the heater core hose? i have the part number for this hose but im not sure if its correct since there is no diagram for the heater hoses.
79721-SH3-000
79721-SH3-000
The plug into #27 which goes to the heater core.
#27 should be the same on all EF/ED cars so the diameter of hose should be the same too.
If you don't have any luck, you can always go to an auto parts store and buy some raw tubing.
It won't have all the fancy molded bends, but it should work.
You scare me though... you said this hose is just a little smaller in diameter than the radiator hose.
That's one HUGE heater core fabbed in there!!!
#26 and #25 are the only water hoses that go to the firewall.
but yea, its a little over a foot long, has an almost 90 degree curve just before it connects to the head.
bottom right of the image below.
gwiffer
Jun 29, 2007 03:53 PM
