Post you very high mileage gsr's
Old Dec 15, 2009 | 10:17 PM
rotascircuit's Avatar
Default Post you very high mileage gsr's
Hey I was just wondering how many high mileage gsr's we got there on the streets.
Ill start
1995 civic si 197xxx on cluster and 130k on 1995 gsr motor
runs fine
burns just some oil when I smash her tooooo hard.
Old Dec 15, 2009 | 10:29 PM
regdog77's Avatar
Default Re: Post you very high mileage gsr's
96 4dr gsr 334k before rebuild. 4k on rebuild
Old Dec 15, 2009 | 11:59 PM
334??? WOW and i'm wining about my mileage guess I should't cool dude
did it still run strong or so so?
Old Dec 16, 2009 | 05:58 AM
GagnarTheUnruly's Avatar
Not that high but mine's still very strong at 139k.
Edit: 1996 GS-R
Old Dec 16, 2009 | 06:22 AM
BJIntegra's Avatar
189xxx kilometers on my 95 gsr.
Old Dec 16, 2009 | 08:03 AM
Edit: 1996 GS-R
still.......thats pretty good
does it burn oil? runs good?
Old Dec 16, 2009 | 08:10 AM
john@apf's Avatar
250k+ 4dr 96GSR, still had more to go. Ran strong with no oil burning or smoking.
10k+ on current build in the car now.
Old Dec 16, 2009 | 08:20 AM
so gsr's really can take some beating
I bet if you NEVER beat a gsr it will last forever
Old Dec 16, 2009 | 08:39 AM
OH_1fstgsr's Avatar
1999 GSR 110,000 miles
1993 Del Sol SI 250,000 miles
Old Dec 16, 2009 | 09:08 AM
coryfenton's Avatar
I just sold a 93 ex civic, that had 321xxx on it. Completely stock, ran great, no leaks, no smoke at all.
I was the 3rd owner. My uncle the first, cousin the second. third me. NO REBUILD DONE EVER.
Old Dec 16, 2009 | 09:18 AM
Only (what I assume is) the typical oil loss we all get with VTEC engines. I'm usually half a liter short between oil changes but I always have been. The awesome thing is the compression numbers:
215/214/215/213 no lie. Fuel economy is 36 hwy, and the idle is very even. I just installed BloxA cams and did a valve lash adjustment and the engine is silky smooth. When you get your engine in order and adjust your rockers you'll see how nice it revs afterwards.
I got no dyno or 1/4 mile times to speak to the performance, but I know the engine is happy.
Old Dec 16, 2009 | 09:54 AM
ILS_09's Avatar
How the hell you get better gas mileage than my bone stock gs lol? 36 hyw? Dang, I think the best I ever did was 34 hwy driving granny style. Damm I need to check my compression. I have 160k+ in my teg and I don't think I need a valve adjustment since nothing is ticking.
Old Dec 16, 2009 | 10:12 AM
Damm I lied, it's 34.2 mpg LOL! I checked my records and I got a minimum of 30.4 and a max of 40.1, but an average of 34 mpg. I get about 25 in the city probably.
I've definitely gotten worse than that when I wasn't keeping records. I remember a trip across SD driving into a really bad headwind where we got mid to low 20's going 75.
Old Dec 16, 2009 | 10:22 AM
ILS_09's Avatar
Yeah hahahaha. I thought so lol.
Old Dec 16, 2009 | 10:24 AM
checazzo's Avatar
2000 GSR w/ 167k miles. I am having some clutch issues right now, but inside and out the car is cleeean.
Old Dec 16, 2009 | 10:25 AM
Oh noes, caught in my own web of lies.
Old Dec 16, 2009 | 02:02 PM
enrique323's Avatar
183,xxx miles, still runs strong, might be selling it soon though, need a 4 door
Old Dec 16, 2009 | 03:16 PM
racebum's Avatar
somewhere over 200k. repaint with jdm itr swap. first b18c1 blew at 178k
Old Dec 16, 2009 | 04:47 PM
pliskin679's Avatar
i got a LS with like 120k on it and its ticking like a ****ing bomb /cry. i just bought the car last week too. i havent driven it out of my driveway
Old Dec 16, 2009 | 06:56 PM
95-db6-719's Avatar
dude until you get to 200k thats high mileage, or is that just me. This 150k and lower is not even close to high mileage. If you beat the **** out of it it will decrease the life, or if you beat the **** out of it yet baby it, say full synthetic and ever 3k change, it will still run fine. My LS had almost 160k runs like a ****ing champ, and i beat the **** out of it every single day. redline all the time, almost every day.
I just got a gsr, it has 76k its a 1995 paid 3k for it. last week.lol. runs super strong. needed a brake master cylinder, and the previous owner dropped it on it shitting springs so it sweaks. but D2 coilovers will fix that next semester.
imports if taken care of will run forver, my buddy has a 90 240sx coupe 432,000 miles and he drifts it. still runs fine, boosting it soon till it blows.. lol
Old Dec 16, 2009 | 06:58 PM
95-db6-719's Avatar
ur valves rockers prolly need shimmed. its recommended at 100k to check that and shim it if needed. my ls ticked barely but i think its cause of that, unless you have a knock. then i am sorry that sucks.
Old Dec 17, 2009 | 09:32 AM
nsxtasy's Avatar
H-T Order of Merit
'94 GS-R, 198K miles. Rebuilt at 174K, since then using very little oil (approx 1 quart per 4000 miles).
More on the oil consumption... It was using 1 quart per 1000 miles when it had 130-165K miles on it, was using 1 quart per 500 miles when it had 165-174K miles. At 174K we found some coolant in the oil, indicating that the head gasket was leaking, so that's why we did the rebuild. (Otherwise I would have just kept adding a quart every 500 miles, which is more cost-effective than spending a lot of money for a rebuild.)
Old Dec 17, 2009 | 10:10 AM
jesse0880's Avatar
95 GSR 135K. Sucked up water last month, replaced the snapped rod, she runs like it never happened.
9000rpms's Avatar
Yeah I have an 95 gs-r With 170k miles on original everything. Motor still runs strong! Good compression, only leak is slight around valve cover gasket. I take up close to 8100rpms everyday! Yeah she burns oil just like every honda w/ over 100k. I go through a quart of synthetic oil every 1000 miles easily so I will probably be switching back to good ol' cheap petroleum 5w-30.
When I was using 0w-20 that crap would just disappear in a matter of like 300-400 miles!! It sure ran amazing with this light of an oil in the crankcase though! It wrapped up in rpms a bit faster.
Old Dec 17, 2009 | 10:28 AM
chwkef's Avatar
92 GSR B17A1 230,000 kms. Getting 26 mpg
