99 Accord vtec EX 90000 service
Hi,
I am getting ready for my 93k mileage 99 vtec EX accord's 90k mile service and need a list of what needs done, and appropriate cost. I had a regular 75k service at 77k with no hiccups.
The 60k was done at 69k and included new front brakes, spark plugs distributor cap n rotor; all belts hoses were ok
What quote should I expect from a Honda dealer (S Minnesota)
Of course timing belt stuff is separate, and that quote is $581. Definitely not worth it, as it does not have water pump, tensioner, etc. that I understand better be replaced along with timing belt at 90k.
Here is what I got from NAPA auto care for 589 (50% labor, rest parts). I would confirm if original Honda parts are used. Is there stuff missing in the list below, I know replace coolant n brake fluid should also be there, but open to comments. Thanks!
LABOR
adjust drive belts
Inspect
brake hoses n lines
driveshaft/propeller shaft dust boots
engine cooling system hoses and clamps
exhaust system
fluid n lubricant levels
front brake system
fuel lines n connections
parking brake
rear brake system
steering gear/rack n boots
suspension components
tie rod ends
Replace
air cleaner element
automatic transaxle fluid
cabin air filter
engine oil 4.5qt
engine oil filter
manual transaxle fluid
spark plugs (In-Line4)
rotate tires
PARTS
Air filter BA5248 $22.88
Cabin air filter 89782 $21.70
V Power spark plug OE Service part 2262 4 x 8.38
Replacement wires Prestolite OE/OES 35-4210 $97.23
Synthetic Transmission fluid VERSA 12 x 6.99 = $83.88
LABOR
adjust drive belts
Inspect
brake hoses n lines
exhaust system
front brake system
parking brake
rear brake system
tie rod ends
Replace
air cleaner element
cabin air filter
engine oil 4.5qt
engine oil filter
rotate tires
PARTS
david118383
Sep 18, 2009 11:34 AM
Stew Pidasso
Jan 2, 2008 04:41 AM
rclark1213
Dec 31, 2007 05:21 AM
