possible 94 turboed integra part out
Old Dec 15, 2009 | 02:12 PM
viviorunitia88's Avatar
Default possible 94 turboed integra part out
chicago
ok well im putting up my gray turboed integra for sale. The body is pretty rough especially the front drivers side not horrible just needs a need headlight but it still works fine. There is 230k on the body but almost every aspect of this car has been changed!!! the interior is black and is very clean!!! missing the rear fiber piece to flatten the hatch area.
The suspension has only about 30k on it with new struts and skunk2 coilover springs.
Has new innovative mounts that have a lifetime warranty on..
The motor has had been bilt with forged nippon pistons with rods and a 3 angle port job on the head the machining was done at dons machine shop in WI arp head studs.
The motor work only has about 30k miles on it
it has a gsr trans i do believe its a jdm lsd trans but im not sure anylonger. That trans has about 50k miles on it
It has an exedy stage 3 i think clutch with an 11lb fly wheel with only about 15k on it.
Right now its on gray honda rims but i do have a set of eneki with almost new tires literly only about 1000 miles on rims and tires that i can throw in for an extra $300
For the turbo system it has 550dsm injectors
Turbo is an air research to4e wich is now more know as garret that turbo only has about 1500 miles on it vbanded cold and hot side . amazing spool and boost properties
hks ssq bov
godspeed fmic
welbro 255 fuel pump
new fuel filter
h22 throttle body
tial knock off wastegate but works amazing cant even tell the diffrent between the real an non real wastegates
radiaitor is an al rad but the mounting points had to be fabed because of the turbo positioning.
Ecu is a chipped p75 with crome software and the usb programmer.
Does need a tune since the turbo is finaly broke in
Had the gauge cluster dual gauge pod with an autometer boost guage and i will take my wideband out of the car before the car is sold. i was just borrowing it till i was going to get it tuned but unfortunately i just want an mr2 again.
has an full 2.5in exhaust name is unknown but no cat and flows and sounds nice!!
If you could paint this car it would be absolutely amazing fun reliable car.
i think im forgetting some suspension stuff but i think that may be it.
just old add thing will post more details later. Will part everything and sell the shell just metal for $300 after everything is gone. shoot an offer on some parts and ill be back
GSRDEAN
Dec 25, 2010 09:47 PM
viviorunitia88
Jan 11, 2010 07:00 AM
xi abla ix
Northeast (Sales)
12
Dec 8, 2008 08:04 PM
xi abla ix
Nov 29, 2008 09:40 AM
mugenteggy001
Mar 7, 2008 12:28 AM
