Are all H22's interchangeable ?
Old Dec 15, 2009 | 05:49 AM
carlitosway12345678's Avatar
Default Are all H22's interchangeable ?
According to my knowledge every H22 stamped, block, head, intake manifold, etc, can be bolted together. Am i wrong?
Im looking at an H22 out of a 92-96 prelude, to put in my 1997, fifth gen, and im second guessing myself.. Any insight for me?
Old Dec 15, 2009 | 05:51 AM
Default Re: Are all H22's interchangeable ?
+ its also a JDM engine, if that makes a difference.
Old Dec 15, 2009 | 05:53 AM
Rosko's Avatar
For the most part yes. There is the 5th gen "sh" Prelude that has the ATTS mounts on the back of the block which is a little goofy. Its still stamped H22a4, thats the only one to watch out for unless thats what you currently have then thats what you would want to replace it with.
Only issues with going from a 97 back to a 91-96 is that if you get one pre 96 it will be obd1 so the oil pump and distributor would be different.
Anything 92-96 will have different injectors but all that stuff could be swapped over from your 97.
Old Dec 15, 2009 | 06:03 AM
oil pump and distributor... ok cool. Yeah mine is the base, so we're all good. Sweeeet. You rock my socks man. thanks.
Old Dec 15, 2009 | 06:30 AM
Rosko's Avatar
The fuel injectors will be different too so make sure you swaw those over too. Also the throttle body won't have the MAP sensor mounted to it since its obd1 so that could be swapped or just swap the entire manifold.
Old Dec 15, 2009 | 04:13 PM
92civlude's Avatar
Honda has a different head gasket p/n for open deck/closed deck blocks. so be sure to get the head gasket to match the block.
ColbyCD5
Aug 11, 2013 04:38 PM
b20forlife
Jan 11, 2010 04:05 PM
PHREAK
Oct 31, 2005 05:41 PM
iakona
Apr 30, 2004 07:51 PM
Bigjussin
Mar 4, 2004 03:47 PM
