O2 pin location on ECU...
Old Sep 2, 2002 | 09:28 PM
See Are X's Avatar
Default O2 pin location on ECU...
Can somebody please tell where the O2 sensor wire goes into the ECU? on a 90-91 CRX Si...I've been told it was C16. I just want to make sure.
Old Sep 3, 2002 | 04:46 AM
91sifreak's Avatar
New User
Default Re: O2 pin location on ECU... (See Are X)
Check C-speedracing.com but yes that is the correct pin for O2 number two.
Old Sep 3, 2002 | 06:41 AM
MADEINIRAQ's Avatar
Default Re: O2 pin location on ECU... (91sifreak)
C8 is o2 sensor. and C16 is for the second o2 sensor if you have a pre-obd b16a1
Old Sep 3, 2002 | 06:57 AM
USDM 4G VTEC's Avatar
Default Re: O2 pin location on ECU... (madeiniraq)
sorry but u have it reversed
on USDM PM6 the C16 its the primary O2 pinout, and theres no second O2..... the C8 its an empty pin on USDM ecu's
on JDM PR3(PWO) the C16 its the primary O2 and C8 its the secondary O2.....
Old Sep 3, 2002 | 07:14 AM
FUP23's Avatar
New User
Default Re: O2 pin location on ECU... (JDM EF9)
jdm ef9 is right ....c16 is primary ...c8 is secndary
Old Sep 3, 2002 | 10:38 AM
Urban Business
Guest
Posts: n/a
Default Re: O2 pin location on ECU... (Devin17)
yeppers. bottom right pin on ecu (c connector, but thats irrelivant) single white wire. runs into a brown insulator along the way inthe harness
birdtc1
Feb 24, 2010 10:13 AM
HONDA RR
Sep 16, 2005 03:53 PM
crxludeT66
Mar 27, 2003 05:36 AM
Rywire
Jan 4, 2003 09:53 PM
gtpilot
Dec 12, 2002 12:27 PM
