Suspension & Brakes Theory, alignment, spring rates....
ek rear lca on del sol...??
Old Dec 14, 2009 | 07:07 AM
hondapimp125's Avatar
Default ek rear lca on del sol...??
ok so i know that the ek rear lca's are like an inch longer than the eg ones and what not... i was just wondering thou if it were possible to put ek rear lca's on an eg and be able to drive around like it were normal... i realize there will be massive amount of rear camber but is it possible?
Old Dec 14, 2009 | 11:47 AM
Default Re: ek rear lca on del sol...??
anybodyy???
Old Dec 14, 2009 | 11:54 AM
phunhaus's Avatar
The issue would be toe, not camber.
Anything is possible but some things are terrible ideas. This is one of them.
Old Dec 14, 2009 | 12:22 PM
LA_HONDAS's Avatar
it wont work
Old Dec 14, 2009 | 04:54 PM
alright thanks guys, i think im still gunna look into it... i was hoping to hear from someone who has done it, a deeper explaination.
Old Dec 14, 2009 | 06:29 PM
phunhaus's Avatar
The EK arms are between two and three inches longer than the EG. That means you'll be running something like 40 degrees of toe and your wheels will be sitting way outside your fenders. It won't drive like normal, nor will it look like normal. You probably couldn't even back out of a driveway.
But if you want to be the first, go for it.
honda_roger
Suspension & Brakes
Jun 24, 2006 02:24 PM
ATS*Mark
15
Mar 16, 2003 12:31 PM
infamousALLMTR
Jan 2, 2003 10:56 AM
rolow
Nov 8, 2002 06:07 AM
