D16A1 swap
Old Dec 13, 2009 | 09:48 PM
r b k a's Avatar
Default D16A1 swap
Got a hold of a complete d16a1 swap pretty much for free! And it's running fine. All its missing is the ecu and wiring harness. I have an si tranny that I know should work perfectly fine with it, but please correct me if I'm wrong. I've heard these swaps are useless in CRX/EF's but I dont want to let it go to waste! Can someone please help me and let me know what i need to do to get this running in my 90 CRX HF? I've always wanted a ZC and this is the closest I'm ever gonna get haha
Old Dec 13, 2009 | 10:06 PM
DCRB's Avatar
Default Re: D16A1 swap
a quick search on google revealed this:
http://www.d-series.org/forums/gener...-question.html
which had links to these two sites:
http://www.d-series.org/forums/dohc-...nt-issues.html
http://www.quickhonda.net/zc2000.htm
edit: there's this too
https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/d16a1-swap-into-my-civic-2333286/
just google "d16a1 in ef" and you'll find hella stuff
Old Dec 13, 2009 | 10:11 PM
r b k a's Avatar
thanks
ok so now i know the mounts are going to be a problem.
now as for the wiring?
Old Dec 13, 2009 | 10:33 PM
DCRB's Avatar
... shoud be just a standard mpfi swap
Old Dec 13, 2009 | 10:35 PM
r b k a's Avatar
thank you!
Old Aug 31, 2010 | 01:57 PM
staticchmbr's Avatar
also, the si tranny wont bolt up.. you need a d16a1 one. also, if your d16a1 is a vacuum advance one from an 86-87, you will need to get a head/dizzy/crank sensor from an 88-89 one
Old Aug 31, 2010 | 06:06 PM
digitally_remastered's Avatar
people here are so full of useless information....
yes i is possible to install a d16a1 into a ef chassis. there is a trans issue bolting to the actual motor. 2 bolts will not go in no matter what. 1 being an actual trans bolt. and the other being a starter bolt. also, there will have to be a slight grinding of the motors bellhousing area to give he starter room to turn over and spin. if your using a ef transmission you will not have issue bolting the trans into the car, the motor mount will be the big problem.
i know this because of this right now in my garage.
89 dx 5 speed trans. 89 d16a1 engine. little modification.
Old Sep 1, 2010 | 07:42 AM
i meant, that it was not just a bolt in affair.. needs some work. plus i dont recommend using anything with missing bolts, but you can if you want.
Old Oct 11, 2010 | 05:36 PM
brain_man's Avatar
what are the acura parts needed in a d16a1 swap in a 1st gen crx
B00sted Eg2
Feb 21, 2009 05:50 AM
kyle1jzsupra
Aug 20, 2008 10:19 AM
mycrxsucks
14
Jun 21, 2005 05:01 AM
eh2..765
13
Jan 25, 2005 03:41 PM
The Brown Kid
Jun 2, 2003 12:20 PM
