question about b16swamp into a crx hf?
see i have a 88hf crx and i have already the tranny and the motor and mounts but my main concern are the axels do i have to change all the bearing assembly the hubs or cuz is an hf so i don't really know some fried told me to use the the b-series axels and just to change the outer end of the axel to a single cam the ones i have on hf's outer axels end would that work? or any other ideas on how to do it?
if you want to make life easy just do the whole spindle. and if you get complete integra spindles you get bigger brakes. the hf is the fuel economy so it has smaller axles and hubs to lighten the drive train down and gets better mpg. you can use any integra spindles 90-2001. I'm not sure but I think the hf is the only civic with the smaller hubs. I know it's the only ef but not sure about eg's or ek's.
Swap to DX/Si/DA spindles/hubs, use a 90-93 Integra rear t-bracket, 90-93 Integra 1/2 shaft, and 90-93 Integra axles, and you're done. I just did an LS swap into my 91 STD hatch, so I went with the DA spindles/brakes. Just make sure to get an alignment afterwards as the DA steering arm is SLIGHTLY shorter and will cause your toe to go out. The DA spindle is also SLIGHTLY taller, so your caster/camber MIGHT go off a LITTLE bit, but not enough to screw anything up majorly. Good luck!
I use a 91 b16 tranny it workes fine. whatever the year the tranny is, that decides the axles u can use. so if u have a newere tranny the axle will not fit on ur 91 hubs.i believe
^^^^you can use what ever year axles you want as long as you use the co-existing axle seal and intermediate shaft. if you have a certain set of axles laying around it is much cheaper to just buy a 11 dollar seal then try to find a different mid shaft and driver shaft. the passenger shaft is the same for all b-series 88-00 civic and 90-01 integra. except for that some have the abs ring on them which doesn't matter unless you have an abs equipt car and then you need that ring on there.
skiracer8148
Apr 12, 2007 07:27 AM
Metal Typhoon
Feb 21, 2007 02:09 PM
mikesrex
12
Sep 18, 2006 06:25 PM
